For Sale Thread
Right that is the normal way, cash.
Thanks for the tip on the credit union looking at it as a camp. I often get involved with clients wanting to buy and sell offgrid and that could be an option. One half of my family was from the Finger Lakes region. Still some there looking for where gramps buried all the cash..... Good Luck!"we go where power lines don't" Sierra Nevada mountain area
Looking to by a magnum MMS 1012, and or a Magnum remote.
PM me as I don't check in as often as I would like
Tony -
i have a few sevcon 48v 17A battery chargers for sale. http://www.sevcon.com/media/46705/pfc_charger.pdf
I bought a group of them and will be using several with my offgrid setup.
i normally used my magnum inverters built in charger but there are times when i use heavy loads and the surges knock off my generator.
This way I can have my generator constantly charging independent of the inverter charger fluctuations.
online Documentation seems a little lite.
I have done some basic testing .
It does have some brains in it that throttle charging as batteries become more charged. it states it has a 4 stage charger algorithms
first connected charger slowly ramps up. maybe takes a minute to get to full current operation.
i had batteries charging at
16.6-16.8amps @50.2v.
15.2amps at 52.5volts
14.8amps at 54volts
14.4 amps at 55volts
14 amps at 55.49volts
13.2amps at 55.49volts
11amps at 55.2volts
10.6amps at 55.18volts
10.2 amps at 55.18 volts
9.8 amps at 55.18 volts
9.4 amps at 55.19 volts
8.8 amps at 55.18 volts
With the above stated results it looks like it wants to hold voltage to 55.18. which seems like a decent value .
the charger has a substantial heatsink, and does not have vents or fans. IN operation with charger sitting on the ground unit warmed about 25-30C over ambient. I would imagine mounted vertically fins on heatsink would perform better.
unit comes with inline fuse, WITHOUT power cord.
one thing I did not check is power factor. I would suspect with the name "pfc charger" it may have good pf figures. But it could also just be naming to mislead consumers. I am currently away from the chargers so will be a few days unit I can check that out.
I am thinking maybe a good alternative to an iota charger. it seems like sevcon is a reputable company.
Anyway looking for $120 per charger.
chargers are located in Utah near ogden
Sears DC Clamp meter is on sale!
Okay, I'll be honest I came to offer my slightly used DC Clamp meter for sale for $40 shipped in the lower US and gloat over the deal I got on a Fluke 376 meter new old stock, in box for $100 with a Fluke 179 and 1507 also new in box (though the 179 does have a calibration # date inscribed, but both still with plastic over the LCDs) for another $150! Today was Christmas for me!
So I looked up a link for the Sears meter to show a picture, and Sears has the inexpensive clamp meter on sale for $39.99, so I guess I'm keeping mine as a spare.
http://www.sears.com/craftsman-digital-clamp-on-ammeter/p-03482369000P?redirectType=SKIP_LEVEL
I'm not planning on doing any checking of coils, so if anyone is interested in the Insulation Tester (Fluke 1507), I'd be glad to send pictures. Turns out his company, a Wind turbine maintenance company, purchased new meters for their guys each year. He just check the old against the new and set them on a shelf!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Haven't had any batteries for a while - Heres your chance
I have Deka Unigy II 95-33 48v 1540ah 2010 dates available - FOB St Louis - $7500 for 48v
will split for 24v and 12v configurations - All come with buss bar have been float charged in temp controlled environment with maintenance.
PM for more info -
How old are they ?
Mike, looks like they have a 2010 date if I read the data correctly...
the ones in the center of first pic are pretty big, looks like ~ 250 # per 3-2v cells,
http://www.solarelectricsupply.com/deka-unigy-spacesaver-3avr95-78
That is correct 2010 - and 286# ea if I remember right.
what's the best one?
The magnum inverter is no longer for sale. Originally I wanted to sell it and buy a pae model so I could ac couple. No one responded till today. I already have 2 solar controlers and the wire So decided I am going to bury the wire, use the solar controlers and this inverter. I just dreaded putting in the extra wire as it is about 280 or 290 feet from the controlers and batterys. So if one of the moderators want to delete this post After anyone gets a chance to read this I would appreciate it.
Batteries Northern California Available - Deka Unigy II 1500ah
Installed 2013 - Float charged maintained - ect
Deka Unigy II AVR 95-33
48v strings $8000 ea will split for 12 or 24 volt systems
comes with all busbar and covers
Available This Month May 2017
I have batteries coming available fairly regularly again - if looking for in the future or in a certain locale let me know
Any remaining warrant on them ?
Deka Warranties unfortunately no longer transfer - However Ive never left anyone stranded with bad batteries and all the issues over the past decade have been in the original shipping to a customer - Please feel free to pm me and we can discuss any concerns - AJ
Good Joke Mike about transferring warranty.
All replace 2012 -1013 Either Deka Unigy II 95-33 or C&D Tech Liberty2000 27P
The C&D are nice in that they dont require the steel cases to be installed - All Float charged and maintained in temp controlled enviroment - no major charge downs - removal due to entire site decommissioning not being removed due to a failing cell somewhere in the string or anything like that.
Those sure are pretty, wish I had a place to put them...
Rancher
XW 4024 inverter/charger 5 years old. Perfect with conduit box
(12) US Battery 1100 AH 2V cells with 4/0 wiring and fuse/disco 3 years old. Excellent 24 Volt bank.
XW mppt-80-600 unopened box with 5 year warranty
Old SW 4024
Old SW 4548
Is the SW 4548 an "E" model, 230 volt, European?
Old SW 4024
Old SW 4548
North American (US) models.
Please e-mail only offgridsolar@sti.net
Prices?Dave Angelini said:XW 4024 inverter/charger 5 years old. Perfect with conduit box
Old SW 4024
Old SW 4548
Please e-mail only offgridsolar@sti.net -
Selling for a widow who has to move back to civilization.Good used Trace SW2512, that is a 12 volt unit.Worked about 9 years then sat in a closet about 9 years. Looks like new, it is in the original Trace box minus the packing material. The owner was very meticulous.PM me if interested, make an offer.
> @icarus said:
> Re: For Sale Thread
> OK,, how's this for an idea. Any ody want my Lister SL2 5 kw diesel genset? Price is ,, free I f you fcover my costs to haul it to a shipping terminal, and you pay shipping. Probably weighs 1000#, and I can only haul it certain times of the year.
> Tony
where are you and the genset located?12 * 300 W (10 fixed rooftop, 2 movable pole mount), Morningstar Tristar MPPT 60, Magnum 4448 PAE, 64 200Ah CALB in 4p16s arrangement with 16 LED Balancers and a Choice BMS300 (It is lousy and I don't recommend but it provides high and low voltage cutoff) -
It'd be nice to have a lister as a backup to the listeroid. but I can't justify it.
Icarus has not been 'on' for a while. He inhabits an island in a lake in northern Ontario
Will sell my website for orphans - it doesn't have a "home" page.
Have 4 48v strings 1 2019 3 2018 2000 ah location Orlando can split 8k per 48v string have to move quick theses are in great condition virtually new - call direct 508-212-7730
Cleaning out the Storage shed ! I found 2 MX60's that worked 12 years + ago.
2 brand new Solar domestic hot water, drainback 7 gallon heat exchangers.
Several of the old C series xantrex/trace solar chargers.
3 new and used Schneider inverters.
A Trace 4048 inverter.
A bunch of disco's, breakers, and wire.
The catch is you have to pick this up in Mariposa CA .
If you email me I can be more specific. No Shipping!!!
Offgridsolar@sti.net"we go where power lines don't" Sierra Nevada mountain area
DC Freezer Stecca 12vdc or 24vdc super efficient. - Perfect working condition $550. You can email me below.. Probably one of the best 6-7 cubic foot Freezers ever made with German Engineering. It staggers me how much they want for this new.
Steca PF166-H Solar Refrigerator or Freezer 12V or24vdc.
Link to product. No shipping ! You must drive to Yosemite area near Mariposa CA. Not a bad drive!
https://www.steca.com/index.php?Steca-PF-166-H-240-H-en#productdescription
Haven’t been around much but have a couple 48v strings 2000ah installed in august of 2018 strings of batteries available this coming week… located in Oakland CA…. Can split if need be all busbar comes with…. Call me directly 508-212-7730 float charged no major outages
