Ok, this time I am serious (Texas)
Hey12
Registered Users Posts: 15 ✭
*Hope this is right thread area*
I just purchased some solar panels (4 Kyocera model# KC130TM) I thought at a really great price. I want to run these panels directly for my koi pond pump. I am not sure as to what exactly besides the panels I will need. The pump is a Little Giant WGP-95-PW Direct Drive Dual Discharge Pump - 4280 GPH. If this worked, it would definitely save on my energy bill. Any thoughts on exactly what I will need to get this running?
Have you bought your charge controller, batteries, and inverter yet?
System 1) 15 Renogy 300w + 4 250W Astronergy panels, Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop) -
I will close this thread... It is best to only have one discussion for your solar setup--Avoid confusion and people answering your questions in separate threads.
Looks like that pump uses 700watts of power and designed to work on 115 volts AC electric...
Considering that the 4-130 watt panels are likely to produce an average of 400 watt sin direct sunlight and you are likely to average 4-5 hours of direct sunlight per-day, I'd sell the panels... and stop thinking about it...
Consider the panels make 2000 watthours perday (likely on the high side) and storage and inverting (switching DC to AC) you will lose half of that...
....and the pump uses 700 watt x 24 hours a day = 16,800watthours. it's not realistic. Consider I have a 5000 watt array and wouldn't consider that load...
Cut and run!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
OK, I will leave this thread open... More responses. (move other posts here):
-Bill- mike95490 Solar Expert Posts: 8,971 ✭✭✭✭✭What is the sticker on the back of the panels :
Vmp __
Voc__
Imp__
Ioc__
max series fuse__
And then, what is the power requirements for your pump
Volts DC ___
Amps DC ___Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
gen: http://tinyurl.com/LMR-Lister , - BB. Super Moderators, Administrators Posts: 30,949 adminThe short answer--It will be fairly expensive to setup a solar power + battery + AC inverter system to run your 700 Watt @ 110 VAC split capacitor pump.
It does depend on what you are trying to do... Do you want a system that only runs during daylight? Do you want 24 hour a day operation? Do you have AC power available to the pump?
If you are trying to save money... First you should measure the power used by the existing pump with a KIll-a-Watt type meter:
https://www.amazon.com/s?k=kill-a-watt+meter&crid=1Q15KNJUHJJFA&sprefix=kill-a-watt,aps,281&ref=nb_sb_ss_i_2_11
You will find a 700 Watt motor running 24x7x30 days a month--That is as much power as the average North American home uses in a month:- 700 Watts = 0.7 kWatts
- 0.7 kWatts * 24 hours per day * 30 Days per month = 504 kWH per month (average home uses around 500-1,000 WH per month)
We can go into great depth of design--But it probably would not be cost effective for you just to power this as a pond pump.
The cheapest and easiest method to solar power on a home is to install a "Grid Tied" solar power system. Basically, solar array + GT AC Inverters which connect directly to your main breaker panel. You (usually) need a building permit, utility approval, and an electrician/solar installer (can be a DIY project--But lots of details to work out first).
GT Solar is usually very cost effective--However, there can be issues (local utility may not allow, HOA may have issues, you need roof/land clear of trees/buildings/shade to get direct sunlight, etc.).
-BillMarc Kurth Solar Expert Posts: 812 ✭✭✭✭Looks like that pump is listed as 115v@6.3 amps. 700 watts. That's a lot of power, depending how many hours per day you want to run.Seems like an application for a DC pump (or more in parallel if needed)
MichaelK said:Have you bought your charge controller, batteries, and inverter yet?
Photowhit said:Looks like that pump uses 700watts of power and designed to work on 115 volts AC electric...
....and the pump uses 700 watt x 24 hours a day = 16,800watthours. i -
Cut and run! -
Hey12, and others:
Here is a link you can use to adjust your email/popup notifications:
https://forum.solar-electric.com/profile/preferences/
BB. said:Hey12, and others:
-Bill -
Could a smaller capacity pump work, if so using a brushless DC pump with pump controller directly off the panels without converting to AC or needing batteries would work. The one I recently purchased is 300W, 800 Gph (50 Lpm) at 6' head, 400W PV or greater recommend, cost ~$170 everything included to install except the panels, pumps as long as there is sufficient power available from the array.
mcgivor said:Could a smaller capacity pump work, if so using a brushless DC pump with pump controller directly off the panels without converting to AC or needing batteries would work. The one I recently purchased is 300W, 800 Gph (50 Lpm) at 6' head, 400W PV or greater recommend, cost ~$170 everything included to install except the panels, pumps as long as there is sufficient power available from the array.
Great idea!Indeed.
Slowly but surely it's starting to be clear to me what the setup would need. In my case, it looks as though maybe I should go with a smaller pump. They may now make similar outputs with less wattage. Panels, batteries, charge controller, inverter. Unless I of course decided to go with a DC sort of pump that could filter the pond. The last thing is figuring how to wire the panels since the conjunction box didn't come pre-wired.
Refer to this link: https://www.cedgreentech.com/article/how-wire-solar-junction-box
I wouldn't want to hurt anyone so an off-grid would be safer for me and the utility workers.
Thank you for the reply bill. It would not be running 24/7. Just during the peak of the day around 4-6 hours.
I'll look into the grid-tied system a bit more, thank you for your response.
I can always power the aerator and not the pump. Thank you for your reply
ok, so as far as the wiring goes on the panels themselves, they don't come preinstalled with mc4 connectors. Instead, they look like the pictures below. Should I be going with the cables in the attached link and run these in parallel? https://www.amazon.com/Solinba-Solar-Extension-Adaptor-Connector/dp/B01L04RGPQ ?
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
