Ok, this time I am serious (Texas)
Hey12
Hey12 Registered Users Posts: 15
I just purchased some solar panels (4 Kyocera model# KC130TM) I thought at a really great price.  I want to run these panels directly for my koi pond pump. I am not sure as to what exactly besides the panels I will need.  The pump is a Little Giant WGP-95-PW Direct Drive Dual Discharge Pump - 4280 GPH. If this worked, it would definitely save on my energy bill. Any thoughts on exactly what I will need to get this running?
    edited September 2020 #2
    What is the sticker on the back of the panels :
    Vmp __
    Voc__
    Imp__
    Ioc__
    max series fuse__
    And then, what is the power requirements for your pump
    Volts DC  ___
    Amps DC  ___
    The short answer--It will be fairly expensive to setup a solar power + battery + AC inverter system to run your 700 Watt @ 110 VAC split capacitor pump.
    It does depend on what you are trying to do... Do you want a system that only runs during daylight? Do you want 24 hour a day operation? Do you have AC power available to the pump?
    If you are trying to save money... First you should measure the power used by the existing pump with a KIll-a-Watt type meter:
    https://www.amazon.com/s?k=kill-a-watt+meter&crid=1Q15KNJUHJJFA&sprefix=kill-a-watt,aps,281&ref=nb_sb_ss_i_2_11
    You will find a 700 Watt motor running 24x7x30 days a month--That is as much power as the average North American home uses in a month:
    • 700 Watts = 0.7 kWatts
    • 0.7 kWatts * 24 hours per day * 30 Days per month = 504 kWH per month (average home uses around 500-1,000 WH per month)
    Typically, with solar power, you try to find the smallest/most efficient "device" you can that does just what you need (and perhaps limited hours per day)--All to save energy usage.
    We can go into great depth of design--But it probably would not be cost effective for you just to power this as a pond pump.
    The cheapest and easiest method to solar power on a home is to install a "Grid Tied" solar power system. Basically, solar array + GT AC Inverters which connect directly to your main breaker panel. You (usually) need a building permit, utility approval, and an electrician/solar installer (can be a DIY project--But lots of details to work out first).
    GT Solar is usually very cost effective--However, there can be issues (local utility may not allow, HOA may have issues, you need roof/land clear of trees/buildings/shade to get direct sunlight, etc.).
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    Looks like that pump is listed as 115v@6.3 amps. 700 watts. That's a lot of power, depending how many hours per day you want to run.
    Seems like an application for a DC pump (or more in parallel if needed)
