Thanks to BB Bill !
Vic
This is not really in the weeds;
Just want to say a public Thank You to BB Bill for ALL that he does here  --  much of those efforts are behind the scenes,  but very much for the good of the community.
Of course  Bill is very,  very helpful in giving Engineering-based advice,  that we all can see,  and admire!
Thanks,  too,  to Northern Arizona Wind & Sun for hosting this great,  and informative Forum,   and also for being an honest, well informed Customer Friendly company to deal with.
Thanks ALL!   Vic
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,182 ✭✭✭✭✭
    edited August 2017 #2
    +1 here.  Thank you Bill "keeper of the peace" B.    Seems what you have needed to do recently would in no way be enjoyable
    As to NAWS, I regularly recommend them to my solar customers.
  • Horsefly
    Absolutely great @BB. - He and just about everyone else on this board is great. Helpful, considerate, and knowledgeable. What was damaged has been repaired!!
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    I will say publicly what I have already said privately: Thank you for all that you do, Sir.
  • Raj174
    Count me in, thanks bill for your kind and patient moderation.
  • softdown
    softdown Solar Expert Posts: 4,042 ✭✭✭✭
    Bill = Best
  • Mangas
    edited August 2017 #7
    Thanks always Bill for your thoroughly researched and well thought out counsel.
    As one of the older Forum members, ten years went by in a blur along with the engineering technology which you are so willing to moderate.
    Also, thanks NAWS for the opportunity to stay informed.
    Let er' Buck!
  • mcgivor
    For the most part a moderators task is a thankless one, the display of support for Bill is a direct reflection of the time, effort and most of all patience (the quality of being patient, as the bearing of provocation, annoyance, misfortune, or pain, without complaint, loss of temper, irritation, or the like)
    Thanks Bill.
  • jonr
    I agree.
    10-4 here|!
  • Estragon
    +1
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
    Yep, Mr. "B" has the patience of a Saint..
  • solar_dave
    Yep me too with the atta boys for BB!  And as for NAWS one of the best in the business IMHO after several dealings with them.
    I was throughly surprised earlier this summer when NAWS had panels in stock with very close specs to replace 4 that had some sort of damage to my 72 panel array install over 7 years ago.  A quick drive to Flagstaff kept the install team from stopping the roofing project.
  • myocardia
    myocardia Solar Expert Posts: 118 ✭✭✭
    Oh, puhleeze! Any person canonized by the church, at least in the last 5-600 years, can't even begin to hold a candle to Bill, in patience or otherwise.*
    *This post might contain some slight hyperbole, but not much.
    DoD= depth of discharge= amount removed from that battery   SoC= state of charge= amount remaining in that battery
    So, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoC
    A/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use)
