Thanks to BB Bill !
Vic
Solar Expert Posts: 3,208 ✭✭✭✭
This is not really in the weeds;
Just want to say a public Thank You to BB Bill for ALL that he does here -- much of those efforts are behind the scenes, but very much for the good of the community.
Of course Bill is very, very helpful in giving Engineering-based advice, that we all can see, and admire!
Thanks, too, to Northern Arizona Wind & Sun for hosting this great, and informative Forum, and also for being an honest, well informed Customer Friendly company to deal with.
Thanks ALL! Vic
Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
+1 here. Thank you Bill "keeper of the peace" B. Seems what you have needed to do recently would in no way be enjoyable
As to NAWS, I regularly recommend them to my solar customers.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Absolutely great @BB. - He and just about everyone else on this board is great. Helpful, considerate, and knowledgeable. What was damaged has been repaired!!Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case.
I will say publicly what I have already said privately: Thank you for all that you do, Sir.
Count me in, thanks bill for your kind and patient moderation.4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset.
Bill = Best
Thanks always Bill for your thoroughly researched and well thought out counsel.
As one of the older Forum members, ten years went by in a blur along with the engineering technology which you are so willing to moderate.
Also, thanks NAWS for the opportunity to stay informed.
Let er' Buck!Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
For the most part a moderators task is a thankless one, the display of support for Bill is a direct reflection of the time, effort and most of all patience (the quality of being patient, as the bearing of provocation, annoyance, misfortune, or pain, without complaint, loss of temper, irritation, or the like)Thanks Bill.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
10-4 here|!
+1Off-grid.
Yep, Mr. "B" has the patience of a Saint..
Yep me too with the atta boys for BB! And as for NAWS one of the best in the business IMHO after several dealings with them.
I was throughly surprised earlier this summer when NAWS had panels in stock with very close specs to replace 4 that had some sort of damage to my 72 panel array install over 7 years ago. A quick drive to Flagstaff kept the install team from stopping the roofing project. -
Aguarancher said:Yep, Mr. "B" has the patience of a Saint..
*This post might contain some slight hyperbole, but not much.
DoD= depth of discharge= amount removed from that battery SoC= state of charge= amount remaining in that batterySo, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoCA/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use)
