Using batteries the first time
KWalters
Registered Users Posts: 2 ✭
Should batteries be at maximum charge when first used? I.e. will it reduce battery life if when I put a load on the batteries for the first time the batteries weren't at maximum charge?
A generic question, a generic answer, You don’t want to drain your battery more than 50% of charge. See the generic chart for further info.
What type of battery are you using ?
ThomOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
Most battery manufacturers recommend a full charge before instalation, failing to do so can have a detrimental effect on future performance, the parameters of said charge vary from one manufacturer to the other, even differing within a single manufacturer for different battery types, the generic answer is yes, fully charge before putting into service, unless instructed otherwise, always following manufacturers recommendations, if available.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
it wont hurt a thing with wet cells .. like Aguarancher said, deep discharge is what you want to avoid and the more shallow you discharge them the better, i'd say to 75% would be ideal ... but no, the first several times you cycle the batts they will just continue to get better, and for me personally i dont like to top them off on a regular basis, i think that hurts them more than it helps, i charge them to 95% or so and if im not using them much i'll nuke them with a equalize charge once a month ..
A "new" battery has probably been sitting for awhile and has some sulfation - a full charge with verification is beneficial.
Seems like solid advice is difficult to dispense without any idea of what the OP has or needs or wants to accomplish......
Thanks for these seven responses. I'm in an African country where the brand/type options are very limited and good quality stuff is hard to find. I just bought five12 V flooded lead-acid batteries this morning. I'm charging them fully before putting them into service, following the manufacturer's instructions as best I can (Chinese translated into English). Thanks for your help!
Typically they are 'commissioned' when the system is setup, by fully charging and equalizing.
I guess these will be 5 batteries in parallel, I would, if possible, fully charge them individually before putting them in parallel.
I would be more concerned about this if they have date codes that don't match (Not all batteries have date codes)
And then verify that all are about the same in resting voltage or specific gravity.I am available for custom hardware/firmware development
Marc Kurth said:Seems like solid advice is difficult to dispense without any idea of what the OP has or needs or wants to accomplish......
I doubt he is looking for a tax write off by destroying them as quickly as he can. -
200W panels for grid tie use, cost about the same as 100 battery panels, Add a decent MPPT charge controller and you are set.
- 628 Discussion Forums/Café
