Using batteries the first time
KWalters
KWalters Registered Users Posts: 2
Should batteries be at maximum charge when first used?  I.e. will it reduce battery life if when I put a load on the batteries for the first time the batteries weren't at maximum charge?
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
    edited June 2017 #2
    A generic question, a generic answer, You don’t want to drain your battery more than 50% of charge. See the generic chart for further info.
  • Thom
    Thom Solar Expert Posts: 196 ✭✭✭
    What type of battery are you using ?
    Thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
  • mcgivor
    edited June 2017 #4
    Most battery manufacturers recommend a full charge before instalation, failing to do so can have a detrimental effect on future performance, the parameters of said charge  vary from one manufacturer to the other, even differing within a single manufacturer for different battery types, the generic answer is yes, fully charge before putting into service, unless instructed otherwise,  always  following manufacturers recommendations, if available.
  • bsolar
    bsolar Solar Expert Posts: 103 ✭✭✭
    it wont hurt a thing with wet cells .. like Aguarancher said, deep discharge is what you want to avoid and the more shallow you discharge them the better, i'd say to 75% would be ideal ... but no, the first several times you cycle the batts they will just continue to get better, and for me personally i dont like to top them off on a regular basis, i think that hurts them more than it helps, i charge them to 95% or so and if im not using them much i'll nuke them with a equalize charge once a month ..
  • jonr
    A "new" battery has probably been sitting for awhile and has some sulfation - a full charge with verification is beneficial.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,175 ✭✭✭✭
    Seems like solid advice is difficult to dispense without any idea of what the OP has or needs or wants to accomplish......
  • KWalters
    Thanks for these seven responses.  I'm in an African country where the brand/type options are very limited and good quality stuff is hard to find.  I just bought five12 V flooded lead-acid batteries this morning.  I'm charging them fully before putting them into service, following the manufacturer's instructions as best I can (Chinese translated into English). Thanks for your help!
    Photowhit Solar Expert Posts: 6,016 ✭✭✭✭✭
    Typically they are 'commissioned' when the system is setup, by fully charging and equalizing.
    I guess these will be 5 batteries in parallel, I would, if possible, fully charge them individually before putting them in parallel.
    I would be more concerned about this if they have date codes that don't match (Not all batteries have date codes)
  • jonr
    And then verify that all are about the same in resting voltage or specific gravity.
  • Lumisol
    Lumisol Registered Users Posts: 374 ✭✭✭
    Probably wants to make his batteries last as long as possible.
    I doubt he is looking for a tax write off by destroying them as quickly as he can. :)
    200W panels for grid tie use, cost about the same as 100 battery panels,  Add a decent MPPT charge controller and you are set.
