Thoughts on a fuse on every battery?
softdown
Solar Expert Posts: 4,026 ✭✭✭✭
Bumped into this while studying various batteries: https://www.amazon.com/Absolute-ANL200-2-Pack-Fuses-Plated/dp/B005EUTLYW/ref=pd_sim_23_2?ie=UTF8&psc=1&refRID=2QA97RC4TSFY6TCRYDK8
Affordable and easy to use. Doesn't look like resistance would be much. If our host carries the same thing, that would be of interest.
Looks a little Mickie Mouse to me, wouldn't want to load that up to 100A let alone 200, judging by the size, using the pin hanger hole as reference. A real fuse looks more like this, rated at 300 DC, 125 with 130% FLA time delay, Cricket lighter for size reference .1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
A fuse that opens the circuit on overload, is a good fuse. That style is commonly used in many industrial applications.
Your question was regarding "a fuse per battery" or not.
Depending upon the battery bank configuration, a 200a rating may be way too big or small.
I believe ANL fuses are what's used in Prosine inverters for reverse polarity fuse.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Lessons from the above;
Electronics must be huge to be real.
Sometimes fuses should be larger than at other times.
Probably used in Prosine inverters.
21 years ago, my yellow page ad was dedicated to custom wiring installations. What have I done to convince some folks that I apparently don't know anything?
Broncos look horrible....feeling cranky.
Sorry, I was wrong the Prosine uses a Littlefuse Mega 125 amp.
Similar size and might work a bit better with the full ring ends. Appears to run about $10, might check with local auto supply as I recall it's used in some cars or trucks.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
The ANL fuses are commonly used in automotive stereo installations with intermittent high loads, the problem I believe is that the blades are undersized and will heat up bofore the fuse element blows, therefore losses. There are some YouTube videos such as (250 amp fuse test) for example. But who knows, been wrong before.
About size, when European style contactors first appeared in North America they were criticized for being too small, the Square D equivalent was 10 times the size so it had to be better it was argued. Side by side tests proved that theory wrong, the smaller contactor pulled in faster and more accurately (all contacts making similtaniously) thereby less contact arc, outperforming the dinosaurs. Today you don't see too many dinosaurs, so big is not necessarily better....but now I've gone off on tangent.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
softdown said:Bumped into this while studying various batteries: https://www.amazon.com/Absolute-ANL200-2-Pack-Fuses-Plated/dp/B005EUTLYW/ref=pd_sim_23_2?ie=UTF8&psc=1&refRID=2QA97RC4TSFY6TCRYDK8
They do seem a bit small at ~ 2.5" x 3/4". I don't think they could consume significant energy without getting very hot. Maybe a couple watts...tops.
Photowhit said:Sorry, I was wrong the Prosine uses a Littlefuse Mega 125 amp.
It might win a Macgivor award...in theory one could simply use a copper wire with similar ability to carry current.
Also wonder about all of the Littelfuses that are rated for 32 volts. I think the only thing a fuse can deal with is excessive current.....whether it is 2 volts or 240 volts.
Arc gap is part of a fuse rating. But I suspect that you already know that.
^^^ I have done quite a bit of basic wiring. Not even close to being an intermediate electrician. Like to think I compensate by generally overbuilding stuff. I'm sure this 8000' shop could handle 110 mph winds. Others think it was built for the bomb.
- 654 Solar Water Pumping
