Thoughts on a fuse on every battery?
softdown
softdown Solar Expert Posts: 4,034 ✭✭✭✭
Bumped into this while studying various batteries: https://www.amazon.com/Absolute-ANL200-2-Pack-Fuses-Plated/dp/B005EUTLYW/ref=pd_sim_23_2?ie=UTF8&psc=1&refRID=2QA97RC4TSFY6TCRYDK8
Affordable and easy to use. Doesn't look like resistance would be much. If our host carries the same thing, that would be of interest.
  • mcgivor
    Looks a little Mickie Mouse to me, wouldn't want to load that up to 100A let alone 200, judging by the size, using the pin hanger hole as reference. A real fuse looks more like this, rated at 300 DC, 125 with 130% FLA time delay, Cricket lighter for size reference .
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    A fuse that opens the circuit on overload, is a good fuse. That style is commonly used in many industrial applications.
    Your question was regarding "a fuse per battery" or not.
    Depending upon the battery bank configuration, a 200a rating may be way too big or small.
    I believe ANL fuses are what's used in Prosine inverters for reverse polarity fuse.
  • softdown
    Lessons from the above;
    Electronics must be huge to be real.
    Sometimes fuses should be larger than at other times.
    Probably used in Prosine inverters.
    21 years ago, my yellow page ad was dedicated to custom wiring installations. What have I done to convince some folks that I apparently don't know anything?
    Broncos look horrible....feeling cranky.
    Sorry, I was wrong the Prosine uses a Littlefuse Mega 125 amp.
    Similar size and might work a bit better with the full ring ends. Appears to run about $10, might check with local auto supply as I recall it's used in some cars or trucks.
  • mcgivor
    The ANL fuses are commonly used in automotive stereo installations with intermittent high loads, the problem I believe is that the blades are undersized and will heat up bofore the fuse element blows, therefore losses. There are some YouTube videos such as (250 amp fuse test) for example. But who knows, been wrong before.
    About size, when European style contactors first appeared in North America they were criticized for being too small, the Square D equivalent was 10 times the size so it had to be better it was argued. Side by side tests proved that theory wrong, the smaller contactor pulled in faster and more accurately (all contacts making similtaniously) thereby less contact arc, outperforming  the dinosaurs. Today you don't see too many dinosaurs, so big is not necessarily better....but now I've gone off on  tangent.
    Those are junk fuses for car stereo installs that belong in an EMP chamber.  only 12v rated.   If WindSun won't carry the Blue Seas Terminal post fuses, I highly doubt they will carry car stereo fuses.
  • softdown
    They do seem a bit small at ~ 2.5" x 3/4". I don't think they could consume significant energy without getting very hot. Maybe a couple watts...tops.
  • softdown
    Looks like Littelfuse/Bussmans are used in Jaguars and BMWs. Looks to be a decent product with the commensurate price.
    It might win a Macgivor award...in theory one could simply use a copper wire with similar ability to carry current.
    Also wonder about all of the Littelfuses that are rated for 32 volts. I think the only thing a fuse can deal with is excessive current.....whether it is 2 volts or 240 volts.
  • Marc Kurth
    Arc gap is part of a fuse rating. But I suspect that you already know that.
  • softdown
    ^^^ I have done quite a bit of basic wiring. Not even close to being an intermediate electrician. Like to think I compensate by generally overbuilding stuff. I'm sure this 8000' shop could handle 110 mph winds. Others think it was built for the bomb.
