Do I need a conduit for out door wiring?
Do I need a conduit for my wire from the solar panels to the inverter on the wall outside? If needed then what type, pvc or metal conduit is best for 1000watt?
    If the wire is exposed, tweakers in your area become attracted to it, and steal it to sell for drugs.
  • cow_rancher
    cow_rancher Solar Expert Posts: 117 ✭✭✭✭
    You can buy direct burial wire... around here the gophers didn't get the NEC memo that said it was OK.
    Rancher
  • Raj174
    I would use electrical PVC. It's fairly easy to measure, cut and fit together. It protects the wiring from solar UV and critters.
    Rick
  • mcgivor
    Advantages, disadvantages, PVC cheap and easy, Steel offers more mechanical protection, including lightning protection, but at the expense of installation cost, method 3, Teck cable, all conductors including ground, no connectors, metallic protection easy installation, really the best of both worlds, consider aluminum to save even more.
  • dennis461
    dennis461 Registered Users Posts: 109 ✭✭✭
    PVC looks like crap after two years in direct sunlight.
    Camden County, NJ, USA
    19 SW285 panels
    SE5000 inverter
    grid tied
    The answer to your question is NO, you do not need to use conduit unless it is locally required. You can use USE2 or 'solar wire' and be okay with NEC code. These wires are resistant to deterioration from direct sunlight. It would look better and be better protected in conduit.
  • cow_rancher
    Rancher
    Somehow I was thinking he was going to bury it, ...never mind...
    Rancher
  • mwk1000
    mwk1000 Registered Users Posts: 3
    I know this is old but I "almost" made a mess by using pvc and not adding expansion joints ( and some paint for better UV block) Luckily I saw a thread on this BEFORE I mounted on the roof and added in the expansion joints - whew scary how much it "grows" in the heat
  • Wheelman55
    Wheelman55 Registered Users Posts: 271 ✭✭✭
    edited August 2022 #10
    One man’s view here.
    Metal conduit above ground, PVC conduit below ground.
    If below ground 2” PVC keeps the critters from being able to get their jaws around the pipe to chew:)
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
