Pics, Movies, or links for personnal sites and blogs (no commercial)
Re: Pics, Movies, or links for personnal sites and blogs (no commercial)westbranch wrote: »as BB Bill says, do not so as He does!...
Unless you want to be a Rock Star.
The Hazards of Electricity -
Hi, I have just started installing my panels. The idea for this method is thanks to Zoneblue. I have put some pictures up. As I progress will put more. I only go to the farm once or twice a month at this stage so progress is slow.
https://plus.google.com/114614245472851365596/photos
Cheers, -
Nothing showing on your link...??
You might have to scroll down the page a bit. I'll attach a picture of the page as it seems to work fine for me.
Cheers, -
I did see the pictures. I like the L bracket that you secured the panels to. I went strait to the wood. I didn't want to buy the aluminum rails. Wish I would have tought of that.
gww -
Yes, aluminium or Unistrut steel was quite expensive. I bought a 3 meter length of 50 mm x 2.5 and cut it with my drop saw and a metal cutting blade which is like a very thin grinding disk. then I drilled them with 8 mm holes and sprayed with Zinc paint. I'll get stainless steel bolts to fix the brackets to the solar panels and also put some sort of long lasting rubber between them so the aluminium doesn't react with the zinc. Next time I go up I'll fit the other four panels and connectors. It took me two full days to build the frame and fit two panels. The others will be quicker to fit. I'll be using these panels to heat a water cylinder though summer.
Cheers, -
If you use stainless nuts and bolts--Make sure you use "anti-seize" compound (grease). Some stainless alloys will seize with hardly more than hand tightening a nut and bolt together.
Re: Pics, Movies, or links for personnal sites and blogs (no commercial)If you use stainless nuts and bolts--Make sure you use "anti-seize" compound (grease). Some stainless alloys will seize with hardly more than hand tightening a nut and bolt together.
I was told to get different compounds of Stainless Steel and it would minimize the binding. I don't know if it's lore, but couldn't hurt if available. I used a drill/driver to mount my panels on my cabin array, and had the nut seize and pull the wrench I was retaining the nut with, right out of my grasp and scared the backing of the panel. FWIW -
I covered the 'scar' with tool dip/liquid electrical tape. I like to keep some on hand for similar problems...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Thanks for the good advice. I have some anti-seize so will use it.
Cheers, -
I have built two wind turbines using stainless all-thread and stainless nuts. Both of them have had threads ruined while taking apart. I am going to have to get another supply of all thread and replace some of them if I ever have to do a deep tear-down.
cheers
gww -
After pricing s/s bolts at $60 for the 6 panels I have done some checking and due to the dryness where I'm located galv should be fine. I'll just put some rubber between the bracket and panels. -
Wow! 1/2 or 3/4" 1/4 SS bolts w/nuts run $2.50 each! ouch! and to think, I was upset at 15-20 cents each here in the states!
Perhaps you were including the bolts through the wood? if you are still allowed arsenic in your pressure treated wood, Galvanized should be fine there...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Pics, Movies, or links for personnal sites and blogs (no commercial)Wow! 1/2 or 3/4" 1/4 SS bolts w/nuts run $2.50 each! ouch! and to think, I was upset at 15-20 cents each here in the states!
Yes S/S 316 grade 8 mm x 25 mm bolt, washer and nut $2.50. Our wood is preserved with copperbase stuff with chrome and arsenic.
Cheers, -
Finally have all six panels up now. I left gaps for the wind to blow though. Have the junction box up and just received the Midnite Classic controller.
Cheers,
https://plus.google.com/114614245472851365596/photos -
Hello all,
After much planning and material finally got my array built. Took about a month working on and off when I could get the help of a friend to do the higher ladder work. The pictures are in the album. Here's the shortcut to Rick and Liz solar system: http://forum.solar-electric.com/album.php?albumid=131
Enjoy the pics.4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
raji
And you get shade to boot. Very nice.
gww -
Re: Pics, Movies, or links for personnal sites and blogs (no commercial)raji
gww
Yes…..unfortunately unavoidable4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
A good starting point for anyone who wants to do a mobile SHTF type build:
http://ecorenovator.org/forum/solar-power/4544-home-made-solar-inverter-generator-hybrid.html
Vehicle roof top solar panels that go where you do:
http://ecomodder.com/forum/showthread.php/solar-assist-vehicle-roof-top-solar-panels-32752.html
I do trash talk cheap inverters and cheap charge controller a lot.
Here is a link to my tiny retreat house, from beginning to end. www.vincentdummer.com/wp
Sunpower 3 x 435 watt panels, 48 v 215 AH battery bank (Sam's club), Midnite Kid and WBjr, Fujitsu 9RLS3 split duct AC, Outback FX 3048T + transformer 2000W 120/220V, GrapeSolar Fridge. -
Very nice job! I am curious to how this goes during the summer. You certainly have the right split. Good Luck!"we go where power lines don't" Sierra Nevada mountain area
Dave, the mini split has been fantastic, what I value is to run it on silent both indoor as well as outdoor unit and it is not noticeable. The panels have been able to supply all the power as by 7 PM when it cools off, my battery system has more than 90% charge.
Hard to beat the Fujitsu 9RlS3. I think I have speced about 10 of them since they came out. Thanks for getting back here!
What did you end up doing with the Sunpower blems from Sun Electronics."we go where power lines don't" Sierra Nevada mountain area
So many dead links in this thread. Could a moderator please clean out the dead wood so the thread doesn't catch on fire?
I will close the thread and "unstick" it.
If anyone wants to highlight their website/work (non-commercial), please feel free to open a discussion (thread) over "In the Weeds" sub-forum.
- 194 Solar Information links & sources, event announcements
- 616 Discussion Forums/Café
