3.2v 100 ah cells with no posts!
robartist
robartist Registered Users Posts: 5 ✭✭
Any idea how to busbar these bad boys?  I ordered a ton of these lithium ion 3.2v 100ah from China but when they arrived they have no posts!  Can I even spot weld or solder busbars thick enough to handle the voltage?  I planned on building a 48 volt battery packs with these.  Now I’m not sure what to do or simple return them after a 4 month shipping wait.
  • mcgivor
    They must have terminals.....a picture would be helpful
  • Photowhit
    DO NOT WELD OR SOLDER THE BATTERIES!!! Lithium doesn't like that sort of thing and only handles a very narrow range of spot welding.
    As Mcgiver said a picture will be nice. I guess they have bolt down terminals?
    Something like this?
    Winston LiFeYPO4 Battery
    You could buy copper plate and drill out for busbars.
  • RCinFLA
    There are prismatic cells that require spot welding to terminals.  Don't try to solder as it will transmit too much heat.
  • robartist
    As you can see from the pics...I’m not sure why they didn’t add the first time around.  No holes for posts!
    You might try some electric vehicle conversion companies and see what they say or have....
    I would not drill and tap them yet until you have exhausted all the other options (and probably not then).
    Bill
    Drill and Tap is the last thing I would do.   How well is the post anchored to the foil layers inside ???  Just need the drill to snag for an instant and rippp   there goes your terminal
  • mcgivor
    Never seen that before, have you asked the supplier, mine came with plastic covers over the terminals but were obviously removable.
