MPPT MT-5 Meter and Amps Input?
timsim00
Registered Users Posts: 15 ✭✭
Hello. I have a Renogy 40A MPPT CC with an MT-5 tracer to reach different inputs/output of the charge controller. I have 4 100W 12V panels in parallel to my charge controller.
My question is the amps IN from the panels being read by the meter. At peak sun time I am pulling in roughly 20+ Amps. As my batteries fill, and need less current from my panels, would this meter reading change as the draw from the CC changes to accommodate my batteries need?
EXAMPLE:
Batteries at 80%, AMPS @ CC input is 20 amps
Batteries at 99%, AMPS @ CC input decreases?
Any ideas?
EXAMPLE:
Any ideas?
That's the way my batteries work, about half way through Absorb, the amps start declining.
You kind of answered your own question in a way, as the battery approaches it's maximum capacity, the current will drop as it becomes saturated, if the CC has an end amp programmable feature, at approximately 2% of the battery Ah capacity, is where you would want to end the absorption and transition to float as there is no benifit of further charging, other than producing gas, consuming water and possibly damaging the battery, assuming they are FLA, sealed batteries would suffer even more.
One observation is you have all your panels in parallel, which kind of defeats the purpose of having a MPPT CC in the first place, ideally you would want the input voltage to be double the battery voltage to take advantage of MPPT, so wiring 2 panels series and 2 strings parallel would be benificial in low temperature and low sunlight conditions, such as overcast days.Batteries at 99%, AMPS @ CC input decreases?
I'm assuming the input to the CC is in proportion to the output of the CC .1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Isn't the series wiring of the panels most likely to help when the panels are hot?I am available for custom hardware/firmware development
If the panels were hot and the VMP was to drop below the requirement to charge the battery, having them in series would also be benificial.jonr said:Isn't the series wiring of the panels most likely to help when the panels are hot?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I suspect that Mcgivor probably nails it with his explanation.
This would be improper wiring for a MPPT charge controller. They need to have higher voltage to work with.timsim00 said:Hello. I have a Renogy 40A MPPT CC with an MT-5 tracer to reach different inputs/output of the charge controller. I have 4 100W 12V panels in parallel to my charge controller.
Any ideas?
Panels should be 2 in series, with 2 strings parallel, to work effectively and most efficiently.
As Mcgivor says, only if the VMP drops below the charge controller/battery requirement. If not, then the lower voltage of parallel wiring usually very slightly improves efficiency (ignoring wiring losses). But I agree that for most "12V" panels, hot panel MPP can drop to 16V, which may be too low for peak efficiency, especially with cool batteries. 2 in series makes sense here.
I can help with this I have used this controler for 2 years .
400watts getting 20 amps is good power .
My amps drop off earlier then I would like and I go into float at 13.6 volts .
My amps hover at 1.5 to 2 amps at 13.6 volts .
The amps don't seam to tapper off much I go from 8/9.5 amps
in full sun laying all most flat facing south west .
I have 220 watts .
To 4/5 amps to the 1.5 to 2 amps float
Don't worry about the mt5 it doesn't really read accurately .
I seam to go into float early controler reads 99/100% full but
my SOC reads 12.6 95% ?
I am always useing power so that seems to fug the controler up a little .
If you put a good load on the battery,the charger will leave float and the amps rise up to power it .
The temp sensor on the charge controler really messes with the charging if the battery's and controler aren't at the same temp . My battery are in a vented box to the out side
the controler is in a un heated area in my trailer the battery wouldent really charge up good
I had to run a genarator and charger .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
I see 17 v in good sun and the battery's get from 13.6 to 14.5/14.6 most of the time .
If you don't dran down the battery 10% the charger just floats all day .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 232 Forum & Website
