MC4 Connector Shortage
Windsun
Solar Expert Posts: 1,164 ✭✭
According to the factory rep, MC4 connector parts are backordered 16 weeks now due to a tooling failure in the Swiss factory as of March 2010.
Re: MC4 Connector Shortage
Is that the only factory for the world of PV OEM's, or for add-in cables onlyPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
it is a good thing that i make my own cables then.
Cheers...
Damani -
Re: MC4 Connector ShortageIs that the only factory for the world of PV OEM's, or for add-in cables only
It is apparently the only factory for all the MC4 connectors and parts in the world. -
Ain't sole sourced parts (probably patented to prevent alternate manufacturers) in a global economy wonderful... :roll:
This is not good... how did "we" end up with only one supplier in the world? No wonder the damn things are expensive. Anyone have an injector molder in there basement? -
who did they pay off to get the 'standard' set that one MUST use MC$'s???
Eric
There is no hard and fast rule that MC4 connectors must be used, other mfg's make acceptable types, such as the Tyco SolarLok, The problem is that most major mfg's have settled on the MC4 type. -
smell of BIG $$$$$ is in the air....
ej
I don't buy this ... many manufactures listed here for MC4
http://www.alibaba.com/showroom/mc4_solar_connector.html
and this is an actual manufacture of MC4's
http://www.nova-group.cn/solar-connector/PV-Cable-coupler-PV-ST01-M-PV-ST01-F.html
Now where wind-sun buys from ( distributor ) maybe having supply issues, but its not only made in one factory in the entire world .. if it was RE world would be all over this.
I couldn't find any Google hit on the tool broken story either and the only hit for MC4 shortage is this thread, none anywhere else -
This report of a shortage was also on the Wrenches List.
I have no idea of its truth or consequences.
boB -
Re: MC4 Connector ShortageSolar Guppy wrote: »I don't buy this ... many manufactures listed here for MC4
All of those are made in China, and there appears to be some issue there also, not sure what it is - but in the past week we have gotten two inquiries from Chinese companies looking to buy those specifically made by MultiContact on the order of 10's of thousands.
Perhaps it is just a general shortage of certain types, but a test a while back (2008?) in one of the electronics magazines (IEEE digest?) showed that most of the Chinese ones failed to meet UL specs.
Aside from that, it is quite possible that the MC rep we talked to is full of it and is just making excuses for a non-delivery screwup for connectors that we ordered back in January. Perhaps there actually no "broken machine" but they oversold to Chinese mfg's and all we get is excuses because we only buy a few 1000 a year.
And why am I not surprised that there is no US manufacturer of them...
