Quick Disconnected for battary bank
i am looking for a Quick Disconnected for my battary bank to my invtered
8 golf cart battarys is how many battary i am useing
what size whould i need
  • audredgeraudredger Solar Expert Posts: 272 ✭✭
    Re: Quick Disconnected for battary bank
    How many amps does your inverter use? You might look at a marine battery switch.
  • icarusicarus Solar Expert Posts: 5,400 ✭✭✭✭
    How many amps are you needing to switch?
    http://bluesea.com/category/1
    tony
  • cajun666cajun666 Solar Expert Posts: 27
    i have a 2000 watt inverter
    i whould have to set up a amp meter to check when i am able to get back to the camp in 2 wk r soo
    i had to go to work and well be away form home for 2 wk
    i have 500 watts of soalr panels
    OK... 2000watt inverter, what voltage? or better what brand and model inverter?
    audredger wrote: »
    12 v 2000 Watt Continuous/4000 Watt Peak Power Inverter
    # 2000 watts continuous power
    # 4000 watts surge capability
    # Input voltage: 11-15VDC
    # Modified sine wave
    # Low voltage alarm protects your battery
    # Auto shutdown
    # Overvoltage shutoff at 15VDC
    # Triple fans for maximum cooling
    # Connector for PCB components
  • RCinFLARCinFLA Solar Expert Posts: 1,280 ✭✭✭
    Do you mean switch or connector?
    For a high current quick connector / dis-connector look at host site for Anderson connectors.
    http://store.solar-electric.com/anhicupoco.html
    RCinFLA wrote: »
    Do you mean switch or plug?
    For a plug/socket look at host site for Anderson connectors.
    switch
    By my calculations, you will need something bigger than 350 amps and, that is the largest switch I know of.
  • crewzercrewzer Registered Users, Solar Expert Posts: 1,832 ✭✭✭✭
    (2000 W (rated) / 80% full-power efficiency) / 11 Vdc min input voltage = 228 Adc. Including a 125% safety factor = 285 Adc.
    Something like this 350 Adc switch should work.
    HTH,
    Jim / crewzer
    Crewzer, this is ment as a polite question, I trying to learn, his inverter has a surge of 4000 watts, 2000 continous. When I said over 350amps, I had figured at 4000 watts. Would that not be the max?
    That's a fair question!
    The NEC 690.8(A)(4) calculation for determining Stand-Alone Inverter (Maximum) Input Circuit Current is the continuous input current rating when the inverter is producing rated power at the lowest input voltage. The calculation I provided earlier for sizing a DC-rated continuous duty circuit breaker is based on my interpretation of this Article.
    Inverters can indeed produce higher than rated power, which would suggest an even higher input current. However, the surge current is usually short-lived, and it typically falls within the surge capability of a circuit breaker, fuse, or switch.
    For example, the "350 Adc" switch I suggested is also rated to handle 600 Adc for 5 minutes, and 900 Adc for 9.75 seconds.
    HTH, and don't be bashful about questions!
    Regards,
    Jim / crewzer
    Thank you Jim, I wanted to know how you came to your figures now, I know. Bashful is not me, Tackles is more my style and I'm trying to modify that.
    audredger wrote: »
    4000 watt is for the surge when u starer some thing up
    it well not care that for long
    2000watts is the max i can use out of this cheap inverted
    i got two of these Blue Sea 3000 HD-Series Battery Switch
    battery to solar panel
    battery to inverted
    SPECIFICATIONS
    Inrush Rating: 0.25 sec (10 repeats) 2,000 Amperes DC
    Cranking Rating: 9.75 sec (10 repeats) 1,200 Amperes DC
    Intermittent Rating: 5 min (UL 1107) 900 Amperes DC
    Continuous Rating: (UL 1107) 600 Amperes DC
    Voltage Rating 48 Volts DC Maximum
    Case Material Reinforced Polycarbonate
    Terminal Hole Size 1/2" (M12)
    Torque 220 in-lbs.
    Product : BLUE SEA 3000 BATTERY SWITCH HD ON/OFF
    Manufacturer : BLUE SEA SYSTEM
    Manufacturer Part No : 3000
    UPC : 632085030001
    $120.00
  • mike95490mike95490 Solar Expert Posts: 8,569 ✭✭✭✭✭
    cajun666 wrote: »
    So are these cool to use in a 48V system? Or will I need to find something more expensive/safe ?
