Quick Disconnected for battary bank
cajun666
Solar Expert Posts: 27 ✭
i am looking for a Quick Disconnected for my battary bank to my invtered
8 golf cart battarys is how many battary i am useing
what size whould i need
Re: Quick Disconnected for battary bank
How many amps does your inverter use? You might look at a marine battery switch. -
How many amps are you needing to switch?
http://bluesea.com/category/1
tony -
i have a 2000 watt inverter
i whould have to set up a amp meter to check when i am able to get back to the camp in 2 wk r soo
i had to go to work and well be away form home for 2 wk
i have 500 watts of soalr panels -
OK... 2000watt inverter, what voltage? or better what brand and model inverter? -
Re: Quick Disconnected for battary bankOK... 2000watt inverter, what voltage? or better what brand and model inverter?
12 v 2000 Watt Continuous/4000 Watt Peak Power Inverter
# 2000 watts continuous power
# 4000 watts surge capability
# Input voltage: 11-15VDC
# Modified sine wave
# Low voltage alarm protects your battery
# Auto shutdown
# Overvoltage shutoff at 15VDC
# Triple fans for maximum cooling
# Connector for PCB components -
Do you mean switch or connector?
For a high current quick connector / dis-connector look at host site for Anderson connectors.
http://store.solar-electric.com/anhicupoco.html -
Re: Quick Disconnected for battary bankDo you mean switch or plug?
For a plug/socket look at host site for Anderson connectors.
switch -
By my calculations, you will need something bigger than 350 amps and, that is the largest switch I know of. -
(2000 W (rated) / 80% full-power efficiency) / 11 Vdc min input voltage = 228 Adc. Including a 125% safety factor = 285 Adc.
Something like this 350 Adc switch should work.
HTH,
Jim / crewzer -
Crewzer, this is ment as a polite question, I trying to learn, his inverter has a surge of 4000 watts, 2000 continous. When I said over 350amps, I had figured at 4000 watts. Would that not be the max? -
That's a fair question!
The NEC 690.8(A)(4) calculation for determining Stand-Alone Inverter (Maximum) Input Circuit Current is the continuous input current rating when the inverter is producing rated power at the lowest input voltage. The calculation I provided earlier for sizing a DC-rated continuous duty circuit breaker is based on my interpretation of this Article.
Inverters can indeed produce higher than rated power, which would suggest an even higher input current. However, the surge current is usually short-lived, and it typically falls within the surge capability of a circuit breaker, fuse, or switch.
For example, the "350 Adc" switch I suggested is also rated to handle 600 Adc for 5 minutes, and 900 Adc for 9.75 seconds.
HTH, and don't be bashful about questions!
Regards,
Jim / crewzer -
Thank you Jim, I wanted to know how you came to your figures now, I know. Bashful is not me, Tackles is more my style and I'm trying to modify that. -
Re: Quick Disconnected for battary bankCrewzer, this is ment as a polite question, I trying to learn, his inverter has a surge of 4000 watts, 2000 continous. When I said over 350amps, I had figured at 4000 watts. Would that not be the max?
4000 watt is for the surge when u starer some thing up
it well not care that for long
2000watts is the max i can use out of this cheap inverted -
i got two of these Blue Sea 3000 HD-Series Battery Switch
battery to solar panel
battery to inverted
SPECIFICATIONS
Inrush Rating: 0.25 sec (10 repeats) 2,000 Amperes DC
Cranking Rating: 9.75 sec (10 repeats) 1,200 Amperes DC
Intermittent Rating: 5 min (UL 1107) 900 Amperes DC
Continuous Rating: (UL 1107) 600 Amperes DC
Voltage Rating 48 Volts DC Maximum
Case Material Reinforced Polycarbonate
Terminal Hole Size 1/2" (M12)
Torque 220 in-lbs.
Product : BLUE SEA 3000 BATTERY SWITCH HD ON/OFF
Manufacturer : BLUE SEA SYSTEM
Manufacturer Part No : 3000
UPC : 632085030001
$120.00 -
Re: Quick Disconnected for battary bankVoltage Rating 48 Volts DC Maximum
So are these cool to use in a 48V system? Or will I need to find something more expensive/safe ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
