MAX rate of charge for Flooded Lead Acid Batteries?
ligwyd
Registered Users Posts: 217 ✭✭
My 630 amp hour battery bank (3 strings of 4-12volt batteries) is currently set at 10% MAX charge rate. So 63 amp MAX in bulk.
The labels on my 12 volt batteries state 10-15 amps Bulk.
So, according to my battery labels the max charge rate should be 45 amps max for all three strings, however I realize that with solar you have to make hay while the sun shines and get the batteries charged up as fast as you can with the avail sunshine.
My question is what max charge rate is common for FLA banks? I know it is a ballpark question, relative to many other factors, however just looking for some feedback none the less......
I have read that 10-13% (of 20 hour capacity) max charge rate is a min recommendation. If I have enough solar could you go higher and if so what is the highest some have safely and successfully used?
What does that even mean? If they thought higher was good, they'd spec 10-25%, or whatever.ligwyd said:I have read that 10-13% (of 20 hour capacity) max charge rate is a min recommendation.
Trojan is quite clear - 13% "Maximum Charge Current" (for FLA), with the note "If charging time is limited contact Trojan Technical Support for assistance." But different manufacturers have different recommendations, and you haven't bothered mentioning which batteries you have. -
That would be true if the batteries were 100 amp hour, but they are 210 amp hour, right, so up to 81 amps (13%) should be ok for bulk charging.
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Usually, it is GEL type batteries (at least in the USA) that end to have a 5% or C/20 limit on the rate of charge.
Another issue could be is if the capacity (AH) of the battery bank is defined at C/100 discharge rate (makes tattery appear larger AH capacity vs the normal C/20 discharge rate battery capacity number we use).
The best source of information regarding how far you can push something - is from the manufacturer. Yes, there is a huge amount of field experience here, but a decent guess cannot be offered without knowing what you have. All flooded batteries are not the same.
Fast charging for offgrid is a balance of the manufacturer and a lesser amount that will often yield the longest life. What is the rush? Go for a walk or a boat ride
Pic of the batteries used in this application and pdf of the spec sheet. C20 discharge rate of 630Ah (210 Ah per string).I'll fire off an e-mail to the vendor and manufacturer and post what I find.Any other feed back is appreciated.Thanks.
The recurring story I've heard, is that flooded and AGM lead acid, can take a pretty beefy charge rate, well above normal rate, till the battery is about 80% full. Then you must reduce to factory specs or heat damage occurs .
Discover put the specs on the battery label for a reason so I would let them tell me what they want and why.I realize that you know this, Mike, but for less experienced people I will point out that around 80% to 85% SOC is where the battery naturally increases in resistance and starts reducing its current draw on its own. That is the definition of going into the Absorb phase of the charging cycle.I always have more questions than answers. That's the nature of life.
It is actually the opposite of what Mike said and reducing this huge current is what can make a battery last well past warranty.
If there is not a rational reason to hit a battery with all of the power you have, you can lessen the thermal shock of internals and get longer life.
I really have never had a FLA not last long past 10 years and the only reason to replace was loss of capacity. I also am not just talking about my 30+ years but hundreds of clients offgrid.
It's all about a balance of available sunlight, loads and generator fuel. When the battery gets warm, slow down.And of course, the factory specs are very important.And maybe late at night I inverted my logic and memory, so the rest of the innertubes will set you straight when I foul up.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks for you all comments. Very much appreciated. Love this forum. My system is up and running and in service and performing well:)
ligwyd said:Pic of the batteries used in this application and pdf of the spec sheet. C20 discharge rate of 630Ah (210 Ah per string).I'll fire off an e-mail to the vendor and manufacturer and post what I find.Any other feed back is appreciated.Thanks.
This is a link to a cut away of that battery https://forum.solar-electric.com/discussion/353896/tubular-lead-acid-battery-cutaway1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Label says to me, 15A max
C or AH at 20 hour discharge time rate C/20
I get 10-42 percent of C from web sites 25% seems common.But I want to know the min charge rate also.When I read the manual for the LiFep04 Winston cells I got in 2014 the said min of .30 of C or 30% and .25 asthe lowest possible. So the series cells say inline voltage wise. And I proved it to myself only as, True.So a 100 amp hour LiFep04 needs at least 25 amps charge or cell imbalance occurs.Now days just buy one with a good BMS that has cell balancing.Now maybe to same applys the Flooded lead acid [min charge amps bulk] also, my guess is C*.05.I got this some where back in 2011 from some site but wish I had printed it or bookmarked it.2500 Ah needs 125 amps. 100 Ah is 5 amps.Maybe I'm wrong if some one has some site please let me know Thanks.
A six year old thread that is dated and the last guy before you is dead! RIP Mike!
The short answer to your question is the "hour rate" of charge needs to be defined. How much current vs long life.
Did the manufacturer use the 24 hour rate that we use for solar or another rate?
For a 400Ah lead-acid battery, the recommended charge rate is typically 10% to 20% of the Amp-hour (Ah) capacity, resulting in a charge current of 40A to 80A. A safe, standard charging current is often considered 0.1C to 0.2C (40A to 80A), while max charging for AGM/Gel is sometimes 30%–50% (120A\)–(200A\))."we go where power lines don't" Sierra Nevada mountain area
Thank yousorry did not notice the dates!must be my firefox install as I saw one first page of Recent Discussions I think.I still be searching for the MIN charge bulk in series rate.have a good weekend.
When you say minimum charge rate well there's trickle Chargers that hardly give any charging it all but for the health of your batteries I understand it to be 5% of your amp hour rating to keep the electrolyte from stratifying
Just a hypothetical question: If ya have 3 stings of multiple batteries and one battery in one string is having a personality problem which then has a higher internal resistance of just that string AND ya are pushing toward the upper range of total output for all three strings, than that sounds like a problem? An expensive problem?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
