Solving a bad battery connection on a car.
softdown
softdown Solar Expert Posts: 4,038 ✭✭✭✭
This battery was disconnected for three years and charged on a regular basis. Its health is still acceptable.
Reconnected and found that I needed to scrub/sand/clean the positive connection every time I sought to start it. And it got worse each time. Had to scrub/sand/clean it after it sat for ONE hour.
Now no amount of scrubbing/sanding/cleaning will create a connection that allows the engine to turn over. Though radio etc have always worked fine.
I’ve never dealt with this phenomena. Seems very odd. Anybody know what is likely happening?
    BB. Super Moderators, Administrators Posts: 33,722 admin
    Sounds like the Battery is going weak/failing... And mostly starting on battery surface charge(?).
    I have a daily driver car with a ~5 year old battery... Getting weak, but still starts car (mild climate, San Francisco area).
    A pickup that had a 6-7 year old battery that was hardly driven, but on full time maintenance charge with this charger:
    https://www.batteryminders.com/2012-12-volt-desulfating-battery-charger-worldwide-use
    Has a "desulfating mode" that seemed to work OK--Although, I would not push desulfator vs just getting a good quality "float" charger.
    Have several Battery Minders of this type, and one did fail after 5+ years--Second and third are still going fine.
  • softdown
    Seems logical. We’ll see how it responds to a truly full charge. If that works - time for a new battery!
  • softdown
    Truly full charge made no difference. Recently tested ~600CCA which should be plenty for a 302CID engine. Guess I’ll try a different battery still.
  • manzanita2
    manzanita2 Registered Users Posts: 35 ✭✭
    Did you clean the cable end too? Probably you did, but you didn't mention it.
    Sol-Ark 12, 3 Pytes V5 100ah batteries, currently six REC 420w panels installed. Ten more panels waiting to be installed.
  • johnsmith76
    johnsmith76 Registered Users Posts: 3
    It sounds like the battery itself may still be fine, but the positive terminal or cable likely has internal corrosion or damage that’s causing a high-resistance connection under load. That’s why small things like the radio work, but the moment the starter needs real current, the connection fails even after cleaning. Often the corrosion travels inside the cable under the insulation, so it looks clean on the outside but can’t carry amperage. At this point the best move is to replace the positive cable or terminal entirely, because if cleaning no longer restores a solid connection, the metal is probably too compromised to reliably carry starter current.
    Exploring renewable energy for remote travel & eco-tourism.
  • Wheelman55
    Wheelman55 Registered Users Posts: 257 ✭✭✭
    I had a “high end” stereo installer wire up a second battery for my truck. It failed miserably due to the fact that the installer used CCA cable instead of pure copper.
    I learned to do all of my own wiring after that.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
