Solving a bad battery connection on a car.
softdown
softdown Solar Expert Posts: 4,081 ✭✭✭✭
This battery was disconnected for three years and charged on a regular basis. Its health is still acceptable.
Reconnected and found that I needed to scrub/sand/clean the positive connection every time I sought to start it. And it got worse each time. Had to scrub/sand/clean it after it sat for ONE hour.
Now no amount of scrubbing/sanding/cleaning will create a connection that allows the engine to turn over. Though radio etc have always worked fine.
I’ve never dealt with this phenomena. Seems very odd. Anybody know what is likely happening?
    BB. Super Moderators, Administrators Posts: 33,742 admin
    Sounds like the Battery is going weak/failing... And mostly starting on battery surface charge(?).
    I have a daily driver car with a ~5 year old battery... Getting weak, but still starts car (mild climate, San Francisco area).
    A pickup that had a 6-7 year old battery that was hardly driven, but on full time maintenance charge with this charger:
    https://www.batteryminders.com/2012-12-volt-desulfating-battery-charger-worldwide-use
    Has a "desulfating mode" that seemed to work OK--Although, I would not push desulfator vs just getting a good quality "float" charger.
    Have several Battery Minders of this type, and one did fail after 5+ years--Second and third are still going fine.
  • softdown
    Seems logical. We’ll see how it responds to a truly full charge. If that works - time for a new battery!
  • softdown
    Truly full charge made no difference. Recently tested ~600CCA which should be plenty for a 302CID engine. Guess I’ll try a different battery still.
  • manzanita2
    manzanita2 Registered Users Posts: 43 ✭✭
    Did you clean the cable end too? Probably you did, but you didn't mention it.
    Sol-Ark 12, 3 Pytes V5 100ah batteries, currently 12 REC 420w panels installed.
  • johnsmith76
    johnsmith76 Registered Users Posts: 4
    It sounds like the battery itself may still be fine, but the positive terminal or cable likely has internal corrosion or damage that’s causing a high-resistance connection under load. That’s why small things like the radio work, but the moment the starter needs real current, the connection fails even after cleaning. Often the corrosion travels inside the cable under the insulation, so it looks clean on the outside but can’t carry amperage. At this point the best move is to replace the positive cable or terminal entirely, because if cleaning no longer restores a solid connection, the metal is probably too compromised to reliably carry starter current.
    Exploring renewable energy for remote travel & eco-tourism.
  • Wheelman55
    Wheelman55 Registered Users Posts: 281 ✭✭✭
    I had a “high end” stereo installer wire up a second battery for my truck. It failed miserably due to the fact that the installer used CCA cable instead of pure copper.
    I learned to do all of my own wiring after that.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
  • softdown
    Sounds very plausible given the batteries 630 CCA and 4.5 resistance. Yet replacing it yielded a couple easy starts so far.
  • manzanita2
    Btw, the specs for my 2013 truck's 302CID engine calls for a 750 CCA battery.
  • softdown
    So far so good with battery replacement. Still say that 630 CCA should also have started it. It starts real easy as a rule.
  • softdown
    Yes
  • softdown
    Been working perfectly with a newer battery. Still say the older 630CCA battery should have at least tried a little. It either started it, rarely, or did absolutely nothing except for turning on the radio.
    Could be internal cable resistance of course.
  • softdown
    So the connection failed again. Took it apart and found a lower arm missing.
    Replaced and it worked with loose connections. Tightened them and now it works sometimes. Ugh.
