12 volt versus 24 volt
alcatel99
Registered Users Posts: 31 ✭✭
Given the same system components batteries and appliance uses how much more efficent will a 24 volt system be over a 12 volt system approx.
Enough to make it worthwhile. Your inverter will work a little less, you'll have more equipment options, you can safely use more watts, and you can save a little bit on wiring.
I'd go 24 volt if running over 600 watts of panels. Higher voltage is more efficient and allows a superior battery configuration as a rule. More serial - less parallel.
This has been discussed dozens of times in the past. Lots of info on search.
I wouldn't go to 24 volt for tiny systems, If you will need more than 220 amp hours at 12 volts, I'd start considering. If you need more than 440 amp hours at 12 volts, I'd go to 24 volts.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
One example: The old Trace DR series inverters. 12 volts 3500 watts surge. 24 volts 4400 watts surge.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Thanks guys
I will always go with 24v too since it is more efficient since I use more than 440 amp hours at 12 volts...
Thanks for replies i decided to go with 24 volt one other question i have is there much difference going with 6 volt batteries in series versus 12 volt batteries in series for space considerations 12 volt batteries would work better for me given that i can match the amp/hrs of both i will probably consider 12 volt Deka Batteries.
The answer is 6V batteries are generally offered in larger capacity, therefore larger individual cells which in turn makes the overall cell count lower to obtain an equal capacity, this results in less maintenance and reduces the need for parrallel strings which is not desirable, high Ah 2 volt cells would be the the best choice in the lead acid world.
- 231 Forum & Website
