MPPT solar charge controller with malfunctioning system
ginapie1081
Registered Users Posts: 1 ✭
How can I fix the malfunction in my solar charge controller system...It just says mppt connecting..and the error indicator is always on but it doesnt indicate what is the problem..Thank you in advance
Welcome to the forum @ginapie1081
Without knowing what the controller is, along with the details regarding the array arrangement it's next to impossible to offer any help. Provide as much information as possible, this will help all in providing some insight into what is going wrong.
This will involve controller specifications, PV module specifications and how the modules are arranged, also include battery nominal voltage and settings along wit battery chemistry.
Think of it as telling a doctor I'm sick, what's wrong, he/she will begin with asking questions, the more detailed the answers, the easier it is to diagnose.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Some MPPT controllers are pretty simple and require connecting to the battery first (Like most PWM) to establish the system voltage. If connected to the solar panel/array first it may set the voltage too high.ginapie1081 said:....It just says mppt connecting..and the error indicator is always on but it doesnt indicate what is the problem...
Also worth checking to see that you are hooking up the panels within the controllers spec's. This would be information we would want to know as well.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
