Need to drain new Samsung cells to ~ 50%. Need a tester/charger etc.
softdown
Solar Expert Posts: 3,824 ✭✭✭✭
They were shipped at very close to 3.9 volts/cell! This will prove hard on the cells unless I can make a significant discharge pretty soon.
Thinking I should invest in a flexible lithium battery charger/discharger/tester etc. Thinking ~$100 or so should get a decent unit. Recommendations?
This unit is flexible and should be on the way pretty soon:
https://www.amazon.com/gp/product/B07Y8NJ84X/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
$100 was a decent estimate for a decent unit.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
With a shipping voltage of 3.9V the cells are likely LIPO, already at 50%, BE VERY CAREFUL they are significantly more sensitive than their LFP cousin, I would highly recommend you study the chemistry you intend to use before dischargeing to a value which could potentially kill the cells, or worse.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:With a shipping voltage of 3.9V the cells are likely LIPO, already at 50%, BE VERY CAREFUL they are significantly more sensitive than their LFP cousin, I would highly recommend you study the chemistry you intend to use before dischargeing to a value which could potentially kill the cells, or worse.
Item specifics
Condition: New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is ... Read moreCountry/Region of Manufacture: Korea, Republic of Product Type: Battery Model: Samsung 30Q
MPN: INR 18650 30Q
Battery Type: Rechargeable Battery Size: 18650 Capacity: 3000mAH Brand: Unbranded
Rechargeable: Rechargeable Application: High Drain Devices Authentic: Authentic Amp Hours: 35 Bundle Listing: No Chemical Composition: Li-Ion Type: Rechargeable Voltage: 3.6 V Cycle Life:: Over 500 Time First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
If you are right then I totally misunderstood a lot of things. This was one of the cells tested here : https://www.youtube.com/watch?v=qMZuHMlRw_0First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
The cycle like - over 500 - is very low for li-ion.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Those are NCA cells some limited information can be found in this link https://batteryuniversity.com/learn/article/types_of_lithium_ion
They are not very safe so research their limitations before using.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:Those are NCA cells some limited information can be found in this link https://batteryuniversity.com/learn/article/types_of_lithium_ion
NCAs are expensive while mine were roughly $4/cell - bought in bulk. Not expensive by any means.
From thebatterystore.com:Samsung 30Q 18650 3000mAh 15A Battery - INR18650-30Q
This is an outstanding cell for those who like high capacity without sacrificing a lot of discharge/drain capability. This is cell is a competitor of the well-known Sony/MuRata VTC6 cell, in which the Samsung 30Q performs very similar and closely with. Many consumers will argue the better of the two, although that is subjective to each persons own demands and needs for their device. This cell has a high capacity of 3,000 mAh in energy and a true maximum continuous discharge/drain rating of 15 amps without any temperature cut involved. It has an outstanding cycle life as well and that should be definitely considered in your purchasing decision, along with its other attributes as well. This cell runs very efficiently and is very stable when used @ 15 amps. This is another great cell that many use in power packs, higher output power banks, BMS's, power tools, and high performance flashlights. This cell has proven itself time and again and is very versatile for may applications.
These cells are 4.2 volts fully charged. So 3.9 isn't such a big concern after all.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
@softdown said, Where did you arrive at that conclusion? NCA's are made by Panasonic for Tesla. Mine are an extremely common Samsung battery.
See attached Samsung pdf which states chemistry as NCA page 31500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks! Appears that $4/cell is a bit of a bargain for such a high performance cell. I'm on p. 50 of DIY Lithium Batteries. Also ordered the Sunkko 737G+ with accessories today. This is all kind of exciting. I may be ready to make my own battery bank in several months - give or take.
And - almost everybody "rating" li-ion batteries are often ignoring a number of possibly important facts. Yet - they kind of have to.Lithium Nickel Cobalt Aluminum Oxide (LiNiCoAlO2) — NCA
Lithium nickel cobalt aluminum oxide battery, or NCA, has been around since 1999 for special applications. It shares similarities with NMC by offering high specific energy, reasonably good specific power and a long life span. Less flattering are safety and cost. Figure 11 summarizes the six key characteristics. NCA is a further development of lithium nickel oxide; adding aluminum gives the chemistry greater stability.
Figure 11: Snapshot of NCA.
High energy and power densities, as well as good life span, make NCA a candidate for EV powertrains. High cost and marginal safety are negatives.
Source: Cadex
Summary TableLithium Nickel Cobalt Aluminum Oxide: LiNiCoAlO2 cathode (~9% Co), graphite anode
Short form: NCA or Li-aluminum. Since 1999Voltages 3.60V nominal; typical operating range 3.0–4.2V/cell Specific energy (capacity) 200-260Wh/kg; 300Wh/kg predictable Charge (C-rate) 0.7C, charges to 4.20V (most cells), 3h charge typical, fast charge possible with some cells Discharge (C-rate) 1C typical; 3.00V cut-off; high discharge rate shortens battery life Cycle life 500 (related to depth of discharge, temperature) Thermal runaway 150°C (302°F) typical, High charge promotes thermal runaway Cost ~$350 per kWh (Source: RWTH, Aachen) Applications Medical devices, industrial, electric powertrain (Tesla) Comments
2019 update:Shares similarities with Li-cobalt. Serves as Energy Cell.
Mainly used by Panasonic and Tesla; growth potential.Table 12: Characteristics of Lithium Nickel Cobalt Aluminum Oxide.
One has to consider the individual cell cost, when the aggregate is counted the cost is roughly double that of LiFePo4 large format, not including the labor of spot welding and the integrity of the battery as a whole, the equipment needed to perform that adds to the overall expense.
Don't take this as discouragement, making a small battery is an educational process, however when you want to upscale to a larger system using larger cells simplifies the whole process, each has its advantages and disadvantages, personally I like to keep it simple, each to their own.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
These cells are very popular for power tools and that will be their usage. I don't foresee making significant power banks from cylindrical cells for a few reasons:
1) Prismatic is much simpler since very few cells are required. Just four 100 aH cells and a BMS and bus bars are needed. Maybe a Victron Battery Saver as well. Can such "home made" batteries be hooked up in serial? A question addressed by the BMS - I think.
2) BMS systems would require soldering on all but LTO cylindrical cells. Soldering injures cells due to the inevitable hot spot incurred.
3) Thermal runaway seems to be a greater risk with a large number of cells. It only takes one cell to rupture to take out the rest. Building your own fuses would help but that would be very tedious and also requires soldering to each and every cell.
Right now I am favoring the purchase of used electric car cells such as BMW or Volt or Leaf. Making small batteries is interesting enough. The economies of making larger batteries seems questionable given the readily available alternatives.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 626 Discussion Forums/Café
