Need to drain new Samsung cells to ~ 50%. Need a tester/charger etc.
softdown
softdown Solar Expert Posts: 4,081 ✭✭✭✭
They were shipped at very close to 3.9 volts/cell! This will prove hard on the cells unless I can make a significant discharge pretty soon.
Thinking I should invest in a flexible lithium battery charger/discharger/tester etc. Thinking ~$100 or so should get a decent unit. Recommendations?
  • softdown
    This unit is flexible and should be on the way pretty soon:
     https://www.amazon.com/gp/product/B07Y8NJ84X/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    $100 was a decent estimate for a decent unit.
  • mcgivor
    edited August 2020 #3
    With a shipping voltage of 3.9V the cells are likely LIPO, already at 50%, BE VERY CAREFUL  they are significantly more sensitive than their LFP cousin, I would highly recommend you study the chemistry you intend to use  before dischargeing to a value which could potentially   kill the cells, or worse.
  • softdown
    Specifics:
    Item specifics
    Condition:
    New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is ... Read more
    Country/Region of Manufacture:Korea, Republic of
    Product Type:BatteryModel:
    Samsung 30Q
    MPN:
    INR 18650 30Q
    Battery Type:Rechargeable
    Battery Size:18650Capacity:3000mAH
    Brand:
    Unbranded
    Rechargeable:Rechargeable
    Application:High Drain DevicesAuthentic:Authentic
    Amp Hours:35Bundle Listing:No
    Chemical Composition:Li-IonType:Rechargeable
    Voltage:3.6 VCycle Life::Over 500 Time
  • softdown
    If you are right then I totally misunderstood a lot of things. This was one of the cells tested here : https://www.youtube.com/watch?v=qMZuHMlRw_0
  • softdown
    The cycle like - over 500 - is very low for li-ion.
  • mcgivor
    Those are NCA cells some limited information can be found in this link https://batteryuniversity.com/learn/article/types_of_lithium_ion
    They are not very safe so research their limitations before using.
  • softdown
    edited August 2020 #8
    Where did you arrive at that conclusion? NCA's are made by Panasonic for Tesla. Mine are an extremely common Samsung battery.
    NCAs are expensive while mine were roughly $4/cell - bought in bulk. Not expensive by any means.
    From thebatterystore.com:
    Samsung 30Q 18650 3000mAh 15A Battery - INR18650-30Q
    This is an outstanding cell for those who like high capacity without sacrificing a lot of discharge/drain capability. This is cell is a competitor of the well-known Sony/MuRata VTC6 cell, in which the Samsung 30Q performs very similar and closely with. Many consumers will argue the better of the two, although that is subjective to each persons own demands and needs for their device. This cell has a high capacity of 3,000 mAh in energy and a true maximum continuous discharge/drain rating of 15 amps without any temperature cut involved. It has an outstanding cycle life as well and that should be definitely considered in your purchasing decision, along with its other attributes as well. This cell runs very efficiently and is very stable when used @ 15 amps. This is another great cell that many use in power packs, higher output power banks, BMS's, power tools, and high performance flashlights. This cell has proven itself time and again and is very versatile for may applications.
  • softdown
    These cells are 4.2 volts fully charged. So 3.9 isn't such a big concern after all.
  • mcgivor
    @softdown said, Where did you arrive at that conclusion? NCA's are made by Panasonic for Tesla. Mine are an extremely common Samsung battery.
    See attached Samsung  pdf which states chemistry as NCA page 3
  • softdown
    Thanks! Appears that $4/cell is a bit of a bargain for such a high performance cell. I'm on p. 50 of DIY Lithium Batteries. Also ordered the Sunkko 737G+ with accessories today. This is all kind of exciting. I may be ready to make my own battery bank in several months - give or take.
    And - almost everybody "rating" li-ion batteries are often ignoring a number of possibly important facts. Yet - they kind of have to.
    Lithium Nickel Cobalt Aluminum Oxide (LiNiCoAlO2) — NCA
    Lithium nickel cobalt aluminum oxide battery, or NCA, has been around since 1999 for special applications. It shares similarities with NMC by offering high specific energy, reasonably good specific power and a long life span. Less flattering are safety and cost. Figure 11 summarizes the six key characteristics. NCA is a further development of lithium nickel oxide; adding aluminum gives the chemistry greater stability.
    Snapshot of NCA
    Figure 11: Snapshot of NCA.
    High energy and power densities, as well as good life span, make NCA a candidate for EV powertrains. High cost and marginal safety are negatives.
    Source: Cadex
    Summary Table
    Lithium Nickel Cobalt Aluminum Oxide: LiNiCoAlO2 cathode (~9% Co), graphite anode
    Short form: NCA or Li-aluminum.        Since 1999
    Voltages3.60V nominal; typical operating range 3.0–4.2V/cell
    Specific energy (capacity)200-260Wh/kg; 300Wh/kg predictable
    Charge (C-rate)0.7C, charges to 4.20V (most cells), 3h charge typical, fast charge possible with some cells
    Discharge (C-rate)1C typical; 3.00V cut-off; high discharge rate shortens battery life
    Cycle life500 (related to depth of discharge, temperature)
    Thermal runaway150°C (302°F) typical, High charge promotes thermal runaway
    Cost~$350 per kWh (Source: RWTH, Aachen)
    ApplicationsMedical devices, industrial, electric powertrain (Tesla)
    2019 update:
    Shares similarities with Li-cobalt. Serves as Energy Cell.
    Mainly used by Panasonic and Tesla; growth potential.
    Table 12: Characteristics of Lithium Nickel Cobalt Aluminum Oxide.
  • mcgivor
    One has to consider the individual cell cost, when the aggregate is counted the cost is roughly double that of LiFePo4 large format, not including the labor of spot welding and the integrity of the battery as a whole, the equipment needed to perform that adds to the overall expense.
    Don't take this as discouragement, making a small battery is an educational process, however when you want to  upscale  to a larger system using larger cells simplifies the whole process, each has its advantages and disadvantages, personally I like to keep it simple, each to their own.
  • softdown
    edited August 2020 #13
    These cells are very popular for power tools and that will be their usage. I don't foresee making significant power banks from cylindrical cells for a few reasons:
    1) Prismatic is much simpler since very few cells are required. Just four 100 aH cells and a BMS and bus bars are needed. Maybe a Victron Battery Saver as well. Can such "home made" batteries be hooked up in serial? A question addressed by the BMS - I think.
    2) BMS systems would require soldering on all but LTO cylindrical cells. Soldering injures cells due to the inevitable hot spot incurred.
    3) Thermal runaway seems to be a greater risk with a large number of cells. It only takes one cell to rupture to take out the rest. Building your own fuses would help but that would be very tedious and also requires soldering to each and every cell.
    Right now I am favoring the purchase of used electric car cells such as BMW or Volt or Leaf. Making small batteries is interesting enough. The economies of making larger batteries seems questionable given the readily available alternatives.
