45 amp TriStar pwm limit
Could i use 4 of these panels on a 45 TriStar pwm @12 volts battery?
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
    It would be close, and if you assume a bit of panel heating, and less then perfect aim, it would work right at the hairy edge.
    44A into a 45A controller.
  • mcgivor
    Morningstar has a string calculator which will provide the answer you're looking for http://string-calculator.morningstarcorp.com
    Yes, unless you live in a very cold area, these would be a fine pairing. Chances of them reaching 11.48 amps is pretty much nil...
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    Morning star string calculator says 3 is the limit.
    Since evergreen has been out of business since. ~2010 these panels are fairly old and i would think that there out put is probably not as good as when they were new.
    My thoughts are to angle 2 panels in an east
    Direction.and 2 in a westerly direction.
    Virtual tracking.
    String ribbon panels does anyone know
    Any thing on this type of panel?
  • mountainman
    @Photowhit winter temperature occasionally
    Gets down to 20 f.
    Little bit, they make the crystalline cells by drawing silk fibers up through a cauldron of molten silicon. Was at one time the most efficient energy wise way to make silicon cells, about 1/2 the time for energy pay back of other cells. It's the reason they got bought up and didn't fold. They used it and licensed it to a German company for a while.
    EE580  Solar Cells Todd J Kaiser Lecture 06 Solar Cell Materials
    One of the founders describes the process thus;
    "In the String Ribbon process, a set of special, parallel "strings" are pulled through a small molten pool of polysilicon inside a custom furnace. A thin wafer is created between the two strings as the polysilicon cools and recrystallizes. The process is continuous, clean, and efficient. By the end of 2003, the company had developed the technology to the point where low-cost production could be achieved."
    Link to article;
    https://www.fool.com/investing/high-growth/2007/08/22/silicon-strings-and-solar-cells.aspx
    Evergreen solar panels have power my life since 2004. Bought some of the last shipment in 2011 for my current array.
  • mountainman
    edited May 2020 #8
    Thanks @Estragon Interesting read.
    Does it seem your older panels production have degraded much since new?
    I haven't been able to find much information
    On there temperature co efficiency.
    But At 23 cents per watt. I'm tempted to give them A try.
    edited May 2020 #9
    Well, this is 'Whit', I haven't seen a lot of degradation, but haven't really been looking or expecting much. I have a panel made in the early 80's producing nicely, though a monocrystalline. My systems tend to be over sized array to battery. I don't use a generator.
    I never expect a solar panel to produce over 75% of the panel rating. There is a difference between the 'flash test' to get Standard Test Condition, STC rating and the Normal Operating Cell Temperature, NOCT values. These tend to be about 75%.
    These means you can expect about 75 watts out of a 100 watt panel. This is what you can expect when the panels are warm/hot. You may approach Standard Test Conditions(STC), in very cold winter days with good direct sun, but it will be rare.
    Also a well designed system will rarely NEED to produce maximum current. Typically systems are designed to reach full charge and stay in the top 80% of battery capacity on sunny days. At around 80% a flooded lead acid battery accepts less current. So there will be no need to have the system producing at maximum current. Even after a cloudy day and your battery bank down to 60%, it will start charging before the sun reaches solar noon when maximum production is possible and you may never see maximum production and the cells will warm, even in winter! So less than STC will be normal. I would never sweat these panels in 20f days.
    These days some manufacturers are printing out and posting the NOCT values on their panels or at least in their literature. Here are some examples;
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,129 ✭✭✭✭✭
      Sad that Evergreen Solar Went under due to the government subsidized solar industry in China all those years ago. They put out a great product but just couldn't compete, as many other mfg. couldn't. That's a great price for those large format 12 volt panels. I have had many of them over the years and they have always been rock solid, well built panels.  I wouldn't hesitate to buy them provided they are in good physical condition.
  • mountainman
    I meant @Photowhit (sorry)
    @littleharbor2 I've only seen  pictures of the panels.
    When I inquired about the age of the panels the seller responded 5 years??
    Now I'm not so sure about the 100 mile ride to check them out.
  • littleharbor2
    Evergreen went out of business more than 5 years ago. I see you already know that. The seller is either flat out lying to you or just plain doesn't know their age and may be guessing. Maybe he was told they were 5years old from a previous owner/seller. At that price I would grab them up before someone else does.
      The evergreen panels I have handled were in great condition and could have passed for 5 years old by looking at them.
    Where are they located?
  • mountainman
    If you don't know say so. I think some people would tell you anything to make a sale.
    Found them on Craigslist in Athens georgia. I believe evergreen Went under about 9 years ago.
    edited June 2020 #14
    mountainman said:.
    The high wattage 12 volt nominal panels were some of the last made, I think mine are manufactured in 2010(some of the last made, though 60 cell 30 volts VMP +/-. Likely a few were made in 2011.  I expect the useful life of solar panels is determined by the owner. I've heard of plants switching out 5-7 year old panels, and also that some of the very earliest still produce.
    FWIW - I believe Evergreen panels were manufactured in China for the most part over the last couple years.
    Ooops, I might have lied to you, looks like the 108 cell panels (3x36 12 volt nominal) were made in USA. The product spec sheet was from 2009, found a back panel photo stating made in USA;
    Evergreen Solar ES-A-205-fa3 205 Watts Solar Panel  Great Solar
    If you do buy them, ask if they have the shipping 'corners', Evergreen mostly didn't use cardboard and had interlocking plastic corners. I still use them today. I've seen them trying to be sold for $2 a piece + shipping on eBay 8-10 years ago;
  • mountainman
    How long does it take to recharge the battery for the scion with that array lol.
    So 12 volt 210 watt evergreen panels are 108 cells.    Sorta like 3 70 watt panels in parallel all in one panel
    1900 watts of panels, I thought it would be quicker...lol!
    That's my understanding, I think this is more common today. 6x18 cells;
    https://www.evergreensolar.com/upload/MAY 2009 NEW LITERATURE/English (US)/US_Datasheet_010609_Lo.pdf
