Mosfet replacement in an inverter
                    M55
                    Registered Users Posts: 2 ✭
                    Hi guys.
No sure if any of you know the 15j321 transistor. I need a replacement for it.
Any suggestions?
Any suggestions?
            STGF15H60DF maybe?
            Thanks a lot guys. Really appreciate the help
            AFAIK, it's an IGBT. I'd just go on ebay and buy an exact replacement.I am available for custom hardware/firmware development
            Be sure to check the transistor driver circuits, they are often blown when the FET fries. And often the bias has to be balanced.
            jonr said:AFAIK, it's an IGBT. I'd just go on ebay and buy an exact replacement.high probability of a counterfeit esp from china.stick with digikey,mouser,ect.while only 1 is shorted often others are wounded.and the driver is often damaged as mentioned.
            Digikey and Mouser are usually a good idea. In this case, they don't have an exact match.I am available for custom hardware/firmware development
- 232 Forum & Website
