Mosfet replacement in an inverter
M55
Registered Users Posts: 2 ✭
Hi guys.
No sure if any of you know the 15j321 transistor. I need a replacement for it.
Any suggestions?
Any suggestions?
STGF15H60DF maybe?
Thanks a lot guys. Really appreciate the help
AFAIK, it's an IGBT. I'd just go on ebay and buy an exact replacement.
Be sure to check the transistor driver circuits, they are often blown when the FET fries. And often the bias has to be balanced.
jonr said:AFAIK, it's an IGBT. I'd just go on ebay and buy an exact replacement.high probability of a counterfeit esp from china.stick with digikey,mouser,ect.while only 1 is shorted often others are wounded.and the driver is often damaged as mentioned.
Digikey and Mouser are usually a good idea. In this case, they don't have an exact match.
- 221 Forum & Website
- 129 Solar Forum News and Announcements
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
