Mosfet replacement in an inverter
Hi guys.
No sure if any of you know the 15j321 transistor. I need a replacement for it.
Any suggestions?
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
  • mike_s
    mike_s Registered Users Posts: 170 ✭✭✭
    STGF15H60DF maybe?
  • M55
    M55 Registered Users Posts: 2
    Thanks a lot guys. Really appreciate the help
  • jonr
    AFAIK, it's an IGBT.  I'd just go on ebay and buy an exact replacement.
    Be sure to check the transistor driver circuits, they are often blown when the FET fries.  And often the bias has to be balanced.
  • kc8adu
    kc8adu Solar Expert Posts: 50 ✭✭✭
    high probability of a counterfeit esp from china.
    stick with digikey,mouser,ect.
    while only 1 is shorted often others are wounded.
    and the driver is often damaged as mentioned.
  • jonr
    Digikey and Mouser are usually a good idea.  In this case, they don't have an exact match.
