Morningstar pwm
mountainman
mountainman Registered Users Posts: 439 ✭✭
I see Morningstar 45 amp and 60 amp
Pwm controllers. That look like the mppt
Controller. But a friend of mine said he has a Morningstar TriStar 30 amp pwm. Has anyone heard of these? I can't find one listed anywhere
The one Im asking about looks like this.
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
    edited April 2020 #2
    Yes, MorningStar still has the Tristar MPPT 30 Amp unit. Here is our host's listing:
    https://www.solar-electric.com/morningstar-tristar-ts-mppt-30.html
  • mountainman
    So they never made a 30 amp pwm. Like the one in the pic?
  • Estragon
    I wouldn't be shocked to learn someone other than Morningstar made a 30a that looks like MS made it.  I've seen other knock off gear whose makers weren't shy about blatently copying.
    I am sorry, I missed read your post... You looking for a PWM 30 amp version.
  • mountainman
    Looks identical to a 45 tristar pwm even has all the Morningstar labels  but with 30 amp?
  • mountainman
    A bit off topic.  with 100f temperature
    What would you recommend as the lowest vmp voltage to charge a 24 volt battery using pwm?
  • mountainman
  • mountainman
    Im guessing since 12 volt panels are 17-18 vmp. Then would it be  34-36 for a 24 volt battery? Anyone.
  • mcgivor
    That's correct for lead acid batteries they need a VMP higher than the maximum battery voltage required  to enable current to flow, at higher battery temperatures the voltages required would be lower unfortunately so is the PVvoltage in high ambient temperatures, this is why 72 cell are recommended as the 60 cell panels are marginal, especially with FLA where equalization may be required.
    The Morningstar string calculator will clarify this if 60 cell panels are input for a 24V nominal system, however they don't include battery chemistry into the calculation. With LFP the story is not the same, 60 cell panels would work just fine since the voltage required is lower and there is no need for equalization . Perhaps thy should update the calculator to include this,  then the use of AGM, which don't need EQ may allow their use. This was a mistake I made in the beginning, although my observations were that it can work, but I did change to MPPT for the 60 cell and use 72 with the PWM.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,044 ✭✭✭✭✭
    edited April 2020 #12
     Look up Fangpusun. They have cloned many Outback, Victron and many other higher end solar products.
  • mountainman
    Fangpusun said that this is no longer available. So probably a knock off.
  • mountainman
    Was speaking of a 30 amp pwm Tristar
  • mcgivor
    edited April 2020 #16
    No such thing,  only  45 and 60A,  30A TriStar is MPPT, the 30A PWM is Proscar which looks completely different.
  • mountainman
    That's what I was thinking my friend must be mistaken about what he has.
