At what time do you shut down unnecessary "luxury loads"?
softdown
softdown Solar Expert Posts: 3,963 ✭✭✭✭
I used the end of float until recently. Logic says I could still do that but it feels odd to burn unneeded energy after 6pm (I'm at 37N). Tomorrow will be here soon enough. Daylight savings feels weird this year, getting older I suppose.
Though I try not to run the microwave within an hour of the end of float.
I've only been full time off grid for less than six years now. Still plenty to learn.
At what time do you shut down unnecessary "luxury loads"? In relation to float - I would think that is logical.
    This is where I love the Weather Underground forecast web page, with the projected cloud density.  I plan loads and recharge a day ahead. It's seldom seriously wrong.
    https://www.wunderground.com/forecast/us/or/eugene/44.09,-123.07
    I don't consider a microwave a luxury load, With close to a 3000 watt array and assuming a reasonable battery bank, perhaps 8-10 kWhs? a microwave running for 2-6 minutes isn't much of a load. You may see a dip in voltage that should return pretty quick. But consider a 10 minute run at a 1000 watts, that's roughly 1/6th of a kWh before considering the effect of running a load at 1/10th of capacity (just a slight penalty).
    I have regularly run a George Forman grill (770 watts on thermostat) for 30 minutes on 4 Golf cart batteries, though admit I'd want to be sure it would be sunny the following day.  And of course ran an air conditioner (420 watts on thermostat) regularly on 4 golf cart batteries drawing down to <50% SOC during the summer. Currently with a system slightly larger than yours I run a window unit 24/7.
  • softdown
    Outside of popcorn I can't immediately think of something that can't be heated with propane. It is quite easy to avoid the microwave during the "dark hours".
    Plus the microwave has developed areas that fail to cook properly in spite of the rotating tray.
  • 706jim
    706jim Solar Expert Posts: 523 ✭✭✭✭
    I used to run a breadmaker for its 4 hour cycle. At that time, my battery bank was 12 GC's, but only about 400 watts of solar. All to do with planning for the available sun.
    Dave Angelini Solar Expert Posts: 6,999 ✭✭✭✭✭✭
    Seriously people cooked pop corn long before microwave ovens.
    As for shutting down luxury loads in a well designed system, it is a matter of looking out the window (or the web). One shifts from electric heat/baking to gas/wood.
     For those who do not want that and for more money one can have a separate battery/inverter system to buy more days of autonomy. I do this one frequently. It buys redundancy also and less chance of problems during wildfire season out west.
  • softdown
    Was that the bank that lasted for 19 years? Remarkable.
    I am having good luck powering two Energy Star freezers with two ~180 watt panels. Indeed, it seems like water consumption went down after adding the second freezer. Leading me to wonder if excess power tends to "boil off" battery water more. In fact, I think it does.
    Then again, the freezers are in a cold garage. A challenge may present during the warmer months of summer. But I doubt it since the garage probably will not see the 70's much at all.
    My four seasons:
    Winter - colder than cold - last 5 months
    Spring - windy and cold - last 2 months
    Summer - somewhat hot - last 3 months
    Fall - fairly reasonable - last 2 months
    Mostly sunny, cold and windy. Lose a lot of time due to excessive winds (though that does alleviate guilt over non productivity).
    BB. Super Moderators, Administrators Posts: 33,689 admin
    This basic type of popcorn shaker was about the best/most handy I have ever used, and no oil needed (that was 50 years ago--Don't know about this specific brand and price):
    https://www.amazon.com/Camp-Chef-Campsite-Popcorn-Popper/dp/B000LGGGH4
    Any heat source, shake and pop, then turn over to dump out the unpopped kernels. Dump popcorn into paper bag, salt, and butter, and you are done.
    Was it this one Bill?  https://www.amazon.com/dp/B005T3P6PM/ref=sbl_dpx_B07N6LSXN5_0
    We have had this for too long to admit in public.
    Nope, the rectangular shaker. Marketed for camping, but works great on a gas stove.
    Bill
  • softdown
    I spent a week watching Q episodes on youtube and bought it hook, line, and sinker. Then decided I needed a few hundred bags of popcorn for all the drama that would soon unfold. Well - nothing really happened. Still have hundreds of bags of popcorn. Hope it stores well.
    I think popcorn might work for diets. Fills you up - with nothing. But there are few nutrients and protein for sustenance either,
  • fratermus
    fratermus Registered Users Posts: 48 ✭✭
    I shut down the opportunity load circuit in the campervan a few points below Vfloat.  This gives a bit of wiggle room in case I add a load on the system that causes a bit of a sag.
    As for popcorn, I cook it in a wok.   The shape is perfect to redirect the unpopped kernels back to the heat.
  • 706jim
    Yes that was the bank. About 12 years old at the time. I would sit there calculating amps and my wife thought I was nuts. But it worked. BTW new for this season will be an Outback Flexmax 80 as has been suggested by a few on this forum.
  • softdown
    Reasonably priced and easy to interface with as well.
