Meters and measurement tools for beginner?
1911
Registered Users Posts: 51 ✭✭
Hello,
Can you anybody reccomend some measurement tools that would be useful to monitor a small first-time 12v solar system?
I am assuming I need a volt and amp meter....anything else?
any particular brands or models you can reccomend?
Thanks!
Thanks!
These are the two systems I am about to wire together and start playing with. Each system will have 2 x 100w 12v panels in series to charge a 84ah battery. (I ordered another mppt cc, so will not be using the pwm cc in the pic)
Any reason to NOT get the Fluke 325?
it looks like it has the right features. -
Fluke are very good professional grade meters, the 325 has the right features, if you can justify the price it's a good choice, there are others at a fraction of the cost which are adequate for the needs of most.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Ok, thanks. Is there a brand or model you can recommend?mcgivor said:Fluke are very good professional grade meters, the 325 has the right features, if you can justify the price it's a good choice, there are others at a fraction of the cost which are adequate for the needs of most.
When I thought I had identified a cheaper model I ran across critical reviews. Several had to do with inaccuracies with low values.
What brand/model would you buy for yourself?
Thanks for the advice! -
Klein Tools makes reasonably priced DVM's for the pros. If you are looking for a clamp meter (recommended) be sure it will meter DC power. Many will do AC/DC voltage but only AC current.
This one has worked well for me... And is ~$12 cheaper than the last time I looked/purchased.
https://www.amazon.com/gp/product/B019CY4FB4
Remember that DC current clamp measurements need to be Zeroed for accurate measurements (and the dc current meter does drift a bit--the nature of the beast).
The Low Z function is nice... There are times when you put a meter on a circuit and read high/unstable voltage--And placing a resistor/load across the terminals, the voltage drops to zero (the High Z function on this meter is a 3 kOhm load).
Ordered, thanks!BB. said:This one has worked well for me... And is ~$12 cheaper than the last time I looked/purchased.
Bunch of tightwads here. This is the meter: https://www.amazon.com/Digital-Current-Resistance-Amperometric-Multimeter/dp/B07Y211PWK/ref=sr_1_1?keywords=digital+clamp+meter&qid=1569701241&s=hi&sr=1-1
I kid!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
LOL, yeah you'll get that on Amazon and Ebay. Often on Ebay things that have been setting on the shelf to long, go for a quarter on the dollar and brand new. Four brush motors are now brushless so these light weight guys were a steal.
It comes w/ free shipping. I just ordered two!softdown said:Bunch of tightwads here. This is the meter: https://www.amazon.com/Digital-Current-Resistance-Amperometric-Multimeter/dp/B07Y211PWK/ref=sr_1_1?keywords=digital+clamp+meter&qid=1569701241&s=hi&sr=1-1
Good show old chap! I keep one in the glove (mink gloves of course) box of each of my 73 fine motorized vehicles. Which reminds me of a present quandary. We are preparing an older 2015 jet for our annual trot about Baja with three of my highly specialized dune buggies. As soon as this old girl is retro-fit we can fit the buggies inside and keep my strippers, I mean girlfriends happy. They like to have a buggy for each pair of girls. Helps hold all the jewelry they are keen to acquire in their shopping sprees.littleharbor2 said:
I'm afraid this particular jet somehow lost some braking power during our multitudinous trips to the Andes and Switzerland. Those short runways in the high mountains I'm afraid. We now require a runway at least a half mile long. Can your airport accommodate that? Is it willing to allow an almost five year old jet to land and transact some local business? She is in rather fine shape in spite of the years. If you can pull the necessary strings I should be able to free up some time for you at my island in the Maldives. My finest yacht is usually tied up there and the crew is, shall we say, absolutely scandalous! They just can't seem to keep a thread of decent clothing on!
I am pretty sure I got you beat....i recently scored 5000 fish hooks for $20 bucks.billybob9 said:LOL, yeah you'll get that on Amazon and Ebay. Often on Ebay things that have been setting on the shelf to long, go for a quarter on the dollar and brand new. Four brush motors are now brushless so these light weight guys were a steal.
The UT210E is about $40 and having a DC clamp is nice for multiple panels in parallel. It physically doesn't stay in one place very well for ohms and volts. Prefer other meters for that.
Here is an Amazon link for NANO's suggested meter and similar (lower cost).They are usually fine for our debugging needs.Just make sure the current clamp is AC + DC rated, not just AC only (both types are good meters, but we use the DC current clamp on battery powered systems. AC only is typical for utility powered systems.Bill
Do you guys ever use a regular multimeter for anything on solar systems?
With lead acid batteries a DC clamp on ammeter is accurate enough, when dealing with lithium cells or electronics a more accurate meter is preferred, these are generally regular type with a higher resolution and the better the quality, more expensive, the more accurate. Personally I use both depending on application.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I use regular (cheap) multimeters a lot, mostly for checking AC and DC voltages and wire continuity. The cheap ones generally work well enough for my needs.Off-grid.
I might be willing to bet that the vast majority of multimeter work is just that - checking voltage. My dad could do a lot with his Fluke, for some reason I felt like I could get by without those capabilities. Which I regret on occasion.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Totally agree, I have been through 3 Fluke 33/34? over 36 years. I paid $104 for this unit, and I considered it a good deal, it will fit 4 Ought wire, Works very well and reading is agreeing with other instruments.1911 said:
Precision voltage references are inexpensive and can help put your mind at ease... I have this one, which apparently isn't available anymore, but it cost about $15 if I recall correctly:There are others like it available from Amazon and elsewhere. Power it from a 15 - 30 volt supply (e.g. two 9-volt batteries in series), and it emits precisely 2.5 / 5.0 / 7.5 / 10.0 volts, depending on a switch setting. Measure the output with your multimeter as a means of testing the accuracy of said meter.I have accumulated 3 or 4 inexpensive multimeters over the years (all under $75). I was happy to see that they're all reasonably accurate -- definitely close enough for my needs. Surprisingly the most accurate one was not the most expensive.
What is the utility of emitting 2.5/5/7.5/10 volts from a device powered by two 9 volt batteries?pdh said:Precision voltage references are inexpensive and can help put your mind at ease... I have this one, which apparently isn't available anymore, but it cost about $15 if I recall correctly:There are others like it available from Amazon and elsewhere. Power it from a 15 - 30 volt supply (e.g. two 9-volt batteries in series), and it emits precisely 2.5 / 5.0 / 7.5 / 10.0 volts, depending on a switch setting. Measure the output with your multimeter as a means of testing the accuracy of said meter.I have accumulated 3 or 4 inexpensive multimeters over the years (all under $75). I was happy to see that they're all reasonably accurate -- definitely close enough for my needs. Surprisingly the most accurate one was not the most expensive.
Another note - it was interesting to find that 9 volt batteries are made of 6 AAA batteries without much wrapping. Some claim that is not always the case. I wonder if that was before AAA batteries became very common.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
The Precision Voltage Reference needs a higher voltage, to produce the Precision Voltage. You have to decide what range of your meter is the crucial range for your expensive batteries, and select via Jumpers, the Voltage you want to check your meter against.If your batteries are 4.3V you chose a range on your meter that gives you good resolution at that voltage and configure the Reference to produce a voltage (5.0000V would be right for measuring 4.3v). The reverence produces 5.0000V, if your meter reads different, it's not adjusted properly and adjustment needs to be done so your batteries will live a long life.9V radio batteries are often made of 6 stacked rectangular cells wrapped in the 9v case.All the batteries I've taken apart as a kid, none were the blue cylindrical cells.
> What is the utility of emitting 2.5/5/7.5/10 volts from a device powered by two 9 volt batteries?The output voltage is not intended to power anything, it's a precise reference voltage that you can use to test your multimeter.For example, my unit says (handwritten on the package it came in) that its 10 volt output is actually 10.00186 volts. So now I measure that 10 volt output with my meters (which only show 2 decimal places of accuracy). I'm hoping to see my meters report 10.00... or maybe 9.99 or 10.01... but if I see 10.15 on my meter for example, then I know that meter is inaccurate.
