Here Comes Trouble: FL bracing for Hurricane Dorian
MrM1
Registered Users Posts: 487 ✭✭✭✭
As of last nite upper steering currents looked like it could probably turn the storm north away from FL and possibly the US. 2pm models today are telling a different story and the central east coast of FL looks to be under the gun. Possibly cat 3.
Here just east of Gainesville FL it could get pretty bumpy. I'll tie down my array Sunday afternoon before the weather deteriorates. Hopefully my sagging battery can keep up. All I really need is about 15 hrs of power per charge from my 24v 435ah system. I'll average about 200-400 watts per hour. But I also got my 4000w Gen tied into my inverter. So I'm pretty ready.
Be safe out there
Be safe out there
REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array
/ MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware
/ OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system
/ Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 /
System, Pics and Discussion
Although probably unknown to most, typhoon Podul, a category 3 storm passed through Asia yesterday, the predictions of its path were very accurate, the eye was to pass directly over us. The predictions of rain were of most concern as 12 inches on already waterlogged soil would mean potential flooding.
At around 11 am there was a brief downpour lasting around 5 minutes, the sky cleared with bright sunshine, the wind however was intense taking down trees and lifting roofing from many homes. We were in the eye of the storm, the areas around us got the rain and wind with localized flooding.
Being that Dorian is still far offshore makes predictions all the more difficult, let's hope it takes a northern path for Florida's sake but that would only put others in harms way, some of whom may not be prepared due to media focus on Florida. Either way trouble is on the way.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Hey Mcgivor, how you weathered it OK. I guess the fact that you are talking here means (at least to some degree) you did. Did your array stay put? That is my main concern.(BTW, the water treated cell is back up to normal operating SG ranges - thanks for walking me thru that procedure)REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
We weathered the storm without any issues, the arrays were unscathed, lost a few trees, mostly due to saturated soil from previous rainfall, the blessing was we were in the eye of the storm, 100 Km to the south there was flooding and perhaps to the north as well but that is a different country, Laos.
My arrays are mounted on welded steel frames embedded in concrete, being at ~30° from horizontal means there is little sail effect, they have endured much higher wind in past storms so not something I'm particularly worried about. Building for the worst case scenario in hurricane prone locations would be wise, I'm amazed that there are so many vulnerable structures in these locations like mobile homes.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:...but that would only put others in harms way, some of whom may not be prepared due to media focus on Florida. .
Of course Trump has never seen a category 5 storm...
I have a third eye in the middle of my forehead from banging my head against the wall.
Photowhit said:mcgivor said:...but that would only put others in harms way, some of whom may not be prepared due to media focus on Florida. .
These storms will go wherever they want, we're in the path for yet another heading about 2°N of our location which probably will result in torrential rain, today we had significant rain for 3 hours, only to further saturate the soil, the runoff is still flowing 8 hours later.
Hurricane Dorian is a strange storm, now stalled over th the Bahamas, the forecast is for it to move north, I don't have much faith in the predictions, anything could happen.
Personally I try to be apolitical but you do have a winner there that's for sure, not worth banging ones head over though, perhaps a vote is the best alternative.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I have a third eye in the middle of my forehead from banging my head against the wall.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
A very polarized country that has to get into politics on everything. Only really smart people never get to see a CAT 5. Crossing my fingers for the OP here!
The equivalent of an EF3 over Nassau for 12 hours. Unprecedented. Good Luck Mon!"we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:A very polarized country that has to get into politics on everything. Only really smart people never get to see a CAT 5. Crossing my fingers for the OP here!
Any thoughts on comedian Chappell's latest show? https://www.rottentomatoes.com/m/dave_chappelle_sticks_and_stones
Dorian is now a Cat 3 that may not hit the US. Yesterday I was reading that it was the most powerful hurricane ever. People just love to scare people it seems. https://news.yahoo.com/tropical-storm-dorian-expected-turn-174952107.html
Looks like we are going to dodge the Dorian Bullet and I probably will not even need the battery backup / Solar system as we will probably never lose power. Looks like there has been significant downgrading this morning but that darn storm still refuses to move much.
1 MPH of movement. Going to be some horrible footage out of the Bahamas if anyone had a battery or watertight camera. Still pounding them after 3 days. Other than the high tides/surge at rivers and beach entries it should just be a wet windy week for east Florida. Dodged the bullet!"we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:
That island appears to be below sea level in the interior.
Definitely like the mountains! Pretty nasty out there for a long time to come. Feel very sorry for them.
We have a dock cleat on out deck as a joke. Pull out a few balusters and boats can tie up at 3,200 feet.
About 150 mile boat trip for the moderator here"we go where power lines don't" Sierra Nevada mountain area
Almost all uphill though. Pretty tough sail.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 226 Forum & Website
- 617 Discussion Forums/Café
