Can anyone tell me where I can get one of these...
            It is not hard to make one... You just need to decide what is "best" and "good" for you...
 To calculate the energy from the sun, offset by the angle of the panel to the sun is Cosine Angle (degrees) ...
 So, a panel that is pointing directly at the sun is Cos 0 degrees = 1.00 ... I.e., 100% of the available sun's energy hits the panel.
 Cosine 10 degrees = 0.98 or 98% of the available energy.
 Say you decide 90% of the solar energy is the boundary between Best and Good... That would be invCos 0.9 = 26 degrees
 And if you decide that 0.71 (71%) is good/bad boundary, that would be 45 degrees.
 Here is a handy chart if you don't have an engineering calculator:
 https://www.mathwarehouse.com/trigonometry/sine-cosine-tangent-chart.php
 Cosine is the angle of the ratio of opposite over hypotenuse.
 One way to lay out what you want (i.e., a circle at 26 degrees) would be to use a protractor to make the angle and use the distance between the "sight" and the target, then draw a vertical line to the angle. That distance would be the radius of the circle.
 Or you can use the Tangent function. Tangent is the angle of the opposite over the adjacent. From above Cos 26d = 0.90 as our "best/good" target line, Tan 26 degrees = 0.488 and the radius would be:- Tan (d) = O/A
- O = Tan (d) * A
- Example of Tan (26 degrees) = 0.488
- Use A = 5 inches between peephole sight and target
- O = Tan (26) * 5 inches = 0.488 * 5 " = 2.44 inch radius circle for target
            Got mine off eBay.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
 Wish I could find one. Disappeared from the face of the planet.littleharbor2 said:Got mine off eBay.
            It's called a SunStalker (one word) manual solar tracker. There's another item of the same name out there but you should be able to locate it online.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
 I knew that. I can't find any other. Love to have plans for one.littleharbor2 said:It's called a SunStalker (one word) manual solar tracker. There's another item of the same name out there but you should be able to locate it online.
 Bill, my sister the math genius could do this. I'm more like a monkey with a soldering when I build guitar amps.BB. said:It is not hard to make one... You just need to decide what is "best" and "good" for you...
- O = Tan (d) * A
            It seems to me something like a long nail at right angles through a piece of wood would do much the same thing. Tilt the panel to make the shadow disappear at noon.Off-grid.
 Do you mind measuring the dimensions of yours and sending them? I can do the drawings on the computer (in Adobe Illustrator) if I just know the dimensions. Thank you. If you mind, that's ok too.littleharbor2 said:Got mine off eBay.
 I'd need to see a visual representation...I'm old...Estragon said:It seems to me something like a long nail at right angles through a piece of wood would do much the same thing. Tilt the panel to make the shadow disappear at noon.
            Tape a pencil (or a straw) to the edge of your panel. and aim panel for no shadowPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
            Another option is a suction cup dart for a toy gun https://www.ebay.com/itm/3-SETS-TOY-SUCTION-DART-GUN/202590110364?hash=item2f2b4fc29c:g:5nEAAOSw27FbLaM7 simply stick on the surface of the module.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
            Tell me the distance between the sight (hole) and the target. And tell me the percentage of 100% harvest (i.e., 10 degrees off center, Cos 10 degrees = 0.985 = 98.5% or 1.5% less than perfect.
 And I will tell you the radius of each circular boundary.
            Upper and lower surfaces are 3 7/8" square and they are 2 7/8" apart. The pinhole is 1/8"2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            What are the radiuses (or diameter) of the excellent/good/bad circles?
            15/16", 1 13/32" and 1 7/8"2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            BTW, The bottom plane is 5 1/2" long with a sharp 180 degree return which is designed to hook the backside of the solar panel frame. It came with one of those spring steel paper clip things to pinch and hold it in place.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            Diameter or radius?
            Center point, outward, radius, correct?
 Diameter, 1 7/8", 2 13/16", 3 3/4".
            Radius, correct.
 InvTan ((15/16) / (2 7/8)) = 18 Degrees
 Cosine 18d = 0.951 = 95.1% harvest eff
 InvTan ((2 13/16) / (2 7/8)) = 44.4 Degrees
 Cosine 44.4d = 0.714 = 71.4% harvest eff
 So, if you like those numbers as your excellent/good/poor harvest numbers (0-18 degrees great, 18-44 degrees good, over 44 degrees off sun is poor), then you can put your two cards 2 7/8 inches apart. Then set a compass to LittleHarbor2's two radiuses and draw the two circles.
 If you have a different spacing between the two cards, then simply multiply the actual card to card spacing by:
 ((15/16) / (2 7/8)) = 0.3261 (excellent/good boundary)
 ((2 13/16) / (2 7/8)) = 0.9783 (good/poor boundary)
 For example, if you have 5" spacing between cards, the first circle will be:
 5" * 0.3261 = 1.63 inches = ~ 1 5/8 inches
 And the second circle will be:
 5" * 0.9783 = 4.891 inches = ~ 4 29/32 inches
- 232 Forum & Website
