Can anyone tell me where I can get one of these...
...or failing that, an exploded diagram with dimensions?
    BB. Super Moderators, Administrators Posts: 33,433 admin
    edited February 2019 #2
    It is not hard to make one... You just need to decide what is "best" and "good" for you...
    To calculate the energy from the sun, offset by the angle of the panel to the sun is Cosine Angle (degrees) ...
    So, a panel that is pointing directly at the sun is Cos 0 degrees = 1.00 ... I.e., 100% of the available sun's energy hits the panel.
    Cosine 10 degrees = 0.98 or 98% of the available energy.
    Say you decide 90% of the solar energy is the boundary between Best and Good... That would be invCos 0.9 = 26 degrees
    And if you decide that 0.71 (71%) is good/bad boundary, that would be 45 degrees.
    Here is a handy chart if you don't have an engineering calculator:
    https://www.mathwarehouse.com/trigonometry/sine-cosine-tangent-chart.php
    Cosine is the angle of the ratio of opposite over hypotenuse.
    One way to lay out what you want (i.e., a circle at 26 degrees) would be to use a protractor to make the angle and use the distance between the "sight" and the target, then draw a vertical line to the angle. That distance would be the radius of the circle.
    Or you can use the Tangent function. Tangent is the angle of the opposite over the adjacent. From above Cos 26d = 0.90 as our "best/good" target line, Tan 26 degrees = 0.488 and the radius would be:
    • Tan (d) = O/A
    • O = Tan (d) * A
    • Example of Tan (26 degrees) = 0.488
    • Use A = 5 inches between peephole sight and target
    • O = Tan (26) * 5 inches = 0.488 * 5 " = 2.44 inch radius circle for target
    If I remember my trig...  :|
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,040 ✭✭✭✭✭
    Got mine off eBay.
  • OldMan
    OldMan Registered Users Posts: 128 ✭✭✭
    edited February 2019 #4
    Got mine off eBay.
    Wish I could find one. Disappeared from the face of the planet.
  • littleharbor2
    It's called a SunStalker (one word)  manual solar tracker. There's another item of the same name out there but you should be able to locate it online.
  • OldMan
    I knew that. I can't find any other. Love to have plans for one.
  • OldMan
    • Tan (d) = O/A
    • O = Tan (d) * A
    Bill, my sister the math genius could do this. I'm more like a monkey with a soldering when I build guitar amps.
  • Estragon
    It seems to me something like a long nail at right angles through a piece of wood would do much the same thing.  Tilt the panel to make the shadow disappear at noon.
  • OldMan
    Got mine off eBay.
    Do you mind measuring the dimensions of yours and sending them? I can do the drawings on the computer (in Adobe Illustrator) if I just know the dimensions. Thank you. If you mind, that's ok too.
  • OldMan
    I'd need to see a visual representation...I'm old...
    Tape a pencil (or a straw) to the edge of your panel. and aim panel for no shadow
  • mcgivor
    Another option is a suction cup dart for a toy gun https://www.ebay.com/itm/3-SETS-TOY-SUCTION-DART-GUN/202590110364?hash=item2f2b4fc29c:g:5nEAAOSw27FbLaM7 simply stick on the surface of the module.
    Tell me the distance between the sight (hole) and the target. And tell me the percentage of 100% harvest (i.e., 10 degrees off center, Cos 10 degrees = 0.985 = 98.5% or 1.5% less than perfect.
    And I will tell you the radius of each circular boundary.
  • littleharbor2
    Upper and lower surfaces are 3 7/8" square and they are 2 7/8" apart. The pinhole is 1/8"
    What are the radiuses (or diameter) of the excellent/good/bad circles?
  • littleharbor2
    15/16", 1 13/32" and 1 7/8"
  • littleharbor2
    BTW, The bottom plane is 5 1/2" long with a sharp 180 degree return which is designed to hook the backside of the solar panel frame. It came with one of those spring steel paper clip things to pinch and hold it in place.
    Diameter or radius?
  • littleharbor2
    Center point, outward, radius, correct?
    Diameter, 1 7/8", 2 13/16", 3 3/4".
    Radius, correct.
    InvTan ((15/16) / (2 7/8)) = 18 Degrees
    Cosine 18d = 0.951 = 95.1% harvest eff
    InvTan ((2 13/16) / (2 7/8)) = 44.4 Degrees
    Cosine 44.4d = 0.714 = 71.4% harvest eff
    So, if you like those numbers as your excellent/good/poor harvest numbers (0-18 degrees great, 18-44 degrees good, over 44 degrees off sun is poor), then you can put your two cards 2 7/8 inches apart. Then set a compass to LittleHarbor2's two radiuses and draw the two circles.
    If you have a different spacing between the two cards, then simply multiply the actual card to card spacing by:
    ((15/16) / (2 7/8)) = 0.3261 (excellent/good boundary)
    ((2 13/16) / (2 7/8)) = 0.9783 (good/poor boundary)
    For example, if you have 5" spacing between cards, the first circle will be:
    5" * 0.3261 = 1.63 inches = ~ 1 5/8 inches
    And the second circle will be:
    5" * 0.9783 = 4.891 inches = ~ 4 29/32 inches
