Schneider Energy Monitor
faccnator
faccnator Registered Users Posts: 35 ✭✭
Why does it look like this?
  • faccnator
    Solar is bringing in 347W, battery is bringing 158W,
    and the load is 74W. Never shows the battery being charged from Solar. Any ideas?
  • faccnator
    Also the MPPT is in float and the battery monitor is showing 82% charge. What am I doing wrong?
    Dave Angelini Solar Expert Posts: 7,025 ✭✭✭✭✭✭
    Is this a new install? You may have the shunt miswired. Is the sun out as the input voltage is too low?
  • faccnator
  • softdown
    softdown Solar Expert Posts: 3,963 ✭✭✭✭
    Listen to Dave. His time in solar harkens back to B.C.
  • faccnator
    I’ve looked at the shunt 100 times and I swear I have it wired the correct direction but I’m going to swap the leads for good measure. I’ll report back
  • faccnator
    Now the flow is backwards
  • mcgivor
    Why is the DC input to the MPPT so low 53.3V, this should be somewhere closer to 100V,  battery 51.2V float? float should be ~54V,.assuming 48V nominallead acid.
    How are panels configured and what are the specs?
    What are the settings for th MPPT?
    What battery type is in use?
  • faccnator
    McGivor, that was at dusk. This is now at night. With the swapped shunt leads. This is even more wrong.
  • mcgivor
    That would make sense being evening didn't notice the time on the screen shot first time, but those are indeed some strange numbers on the graphics, appears the shunt is either not calibrated correctly or faulty.
  • Estragon
    Estragon Registered Users Posts: 4,498 ✭✭✭✭✭
    Just to be sure... are there any negative wires other than the shunt to battery wire on the battery side of the shunt (eg. DC loads, meters, other inverters)?
    How/where is the system grounded?
  • faccnator
    This morning. Rewired the shunt. Check the negative wires. Why doesn’t the battery monitor know when the mppt is charging?
  • faccnator
    Just thought I would follow up. I had the solar charge controller wired to the wrong side of the shunt. Everything has been working great for a week now! Thanks for all the help everyone!
