Cheap Freeze tolerant Charge Controller
KhellSk
Registered Users Posts: 91 ✭✭
Hello
i need a chrg ctrl that can wistand -34F rated 12v at least 5A as cheap as possible. Any of you got suggestion ?
All i can find as an lcd screen on it. I doubt that gonna work.
_____________________________________________
[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah]
[Victron 50/100 700wMax MPPT]
I would think LCD might not be the problem you think it is unless you need to inspect the screen. I've had my Midnight classic's down to -10, but I don't check the screen. It appears to have survived ok, it does use a bit of energy at idle, so maybe warms it a bit.
Our sponsor sells a Morningstar SunSaver 6 (and 10 amps) starting around $45
https://www.solar-electric.com/ss-6.html
You are starting to look at military temp specs. commercial gear may survive but not be accurate
That would prompt me to look into using hi-rel zeners and schottky devices to protect batteries from overcharge if this is just a winter storage situation.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Really cheap controllers probably won't spec an operating temperature range, Morningstar spec -40°F to 113°F, Midnight is another -40°F to 120°F they both have an good reputation and excellent customer support, there may be others.
I've found LCD screens sorta work in the cold, but are really slow to change. Patience is needed if you need to navigate a menu. Plastic, metal, wiring, etc gets quite brittle in such low temps, so a light touch is also needed.
Fingers don't work too well for long either. IMHO, a remote meter/control is worth the $$
okay thanks guys. I am now rethinking my whole setup_____________________________________________[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah][Victron 50/100 700wMax MPPT]
Signature test_____________________________________________[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah][Victron 50/100 700wMax MPPT]
You will not see a signature on mobile device mode.BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
