Cheap Freeze tolerant Charge Controller
KhellSk
KhellSk Registered Users Posts: 91 ✭✭
Hello
i need a chrg ctrl that can wistand -34F rated 12v at least 5A as cheap as possible. Any of you got suggestion ?
All i can find as an lcd screen on it. I doubt that gonna work.
_____________________________________________
[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah]
[Victron 50/100 700wMax MPPT]
  • Photowhit
    I would think LCD might not be the problem you think it is unless you need to inspect the screen. I've had my Midnight classic's down to -10, but I don't check the screen. It appears to have survived ok, it does use a bit of energy at idle, so maybe warms it a bit.
    Our sponsor sells a Morningstar SunSaver 6 (and 10 amps) starting around $45
    https://www.solar-electric.com/ss-6.html
    You are starting to look at military temp specs.  commercial gear may survive but not be accurate
    That would prompt me to look into using hi-rel zeners and schottky devices to protect batteries from overcharge if this is just a winter storage situation.
  • mcgivor
    Really cheap controllers probably won't spec an operating temperature range, Morningstar spec -40°F to 113°F,  Midnight is another -40°F to 120°F  they both  have an good reputation and excellent customer support, there may be others.
  • Estragon
    I've found LCD screens sorta work in the cold, but are really slow to change.  Patience is needed if you need to navigate a menu.  Plastic, metal, wiring, etc gets quite brittle in such low temps, so a light touch is also needed.
    Fingers don't work too well for long either.  IMHO, a remote meter/control is worth the $$ :wink:
    Off-grid.
  • KhellSk
    okay thanks guys. I am now rethinking my whole setup
  • KhellSk
    Signature test
    You will not see a signature on mobile device mode.
    Bill
