TS MPPT 60 first impressions
Note to self: Avoid Morningstar.
Why?Off-grid.
Thems some bold words pardner. You prepared to back that up with something ? I gots a pair of MPPT's and a Sunsaver that are just plumb offended.OldMan said:Note to self: Avoid Morningstar.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
One of the better products with excellent support, what's to avoid?OldMan said:Note to self: Avoid Morningstar.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Mine is still getting a big 2 thumbs up!!!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
Too rich for my blood. I'll take Fangpusun.Estragon said:Why?
That's your prerogative. You might have included that in your post though, as it could be taken as slagging MS quality or whatever.OldMan said:
I have Morningstar inverter and PWM charge controllers, all of which do what they're supposed to quite reliably so far.Off-grid.
And, If and when, you need tech support or warranty support Morningstar is unbeatable. Try that with the copycat company. Likely you will never get a reply to any inquiry.Estragon said:
That's hardly an excuse to "avoid" a specific mfg. Product cost is hardly something to tout as a reason to avoid. It's up front, no hidden fees. And for a superb product thats in the top tier, that's basically set and forget, up front cost avoids a lot of worry and issues. Once you have the first hot summer month under your belt to weed out infant failures, it's pretty much going to run till something external kills it.OldMan said:Too rich for my blood. I'll take Fangpusun.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
TS MPPT 60 chugging along just fine. Hardly ever come by here any more because it just works, take care all!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
