TS MPPT 60 first impressions
Note to self: Avoid Morningstar.
Why?Off-grid.
OldMan said:Note to self: Avoid Morningstar.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
OldMan said:Note to self: Avoid Morningstar.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Mine is still getting a big 2 thumbs up!!!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
mcgivor said:One of the better products with excellent support, what's to avoid?
Estragon said:Why?
OldMan said:Too rich for my blood. I'll take Fangpusun.
I have Morningstar inverter and PWM charge controllers, all of which do what they're supposed to quite reliably so far.Off-grid.
Estragon said:That's your prerogative. You might have included that in your post though, as it could be taken as slagging MS quality or whatever.
OldMan said:Too rich for my blood. I'll take Fangpusun.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
TS MPPT 60 chugging along just fine. Hardly ever come by here any more because it just works, take care all!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
- 616 Discussion Forums/Café
