TS MPPT 60 first impressions
Note to self: Avoid Morningstar.
Why?Off-grid.
Thems some bold words pardner. You prepared to back that up with something ? I gots a pair of MPPT's and a Sunsaver that are just plumb offended.OldMan said:Note to self: Avoid Morningstar.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
One of the better products with excellent support, what's to avoid?OldMan said:Note to self: Avoid Morningstar.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Mine is still getting a big 2 thumbs up!!!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
Too rich for my blood. I'll take Fangpusun.Estragon said:Why?
That's your prerogative. You might have included that in your post though, as it could be taken as slagging MS quality or whatever.OldMan said:
I have Morningstar inverter and PWM charge controllers, all of which do what they're supposed to quite reliably so far.Off-grid.
And, If and when, you need tech support or warranty support Morningstar is unbeatable. Try that with the copycat company. Likely you will never get a reply to any inquiry.Estragon said:
That's hardly an excuse to "avoid" a specific mfg. Product cost is hardly something to tout as a reason to avoid. It's up front, no hidden fees. And for a superb product thats in the top tier, that's basically set and forget, up front cost avoids a lot of worry and issues. Once you have the first hot summer month under your belt to weed out infant failures, it's pretty much going to run till something external kills it.OldMan said:Too rich for my blood. I'll take Fangpusun.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
TS MPPT 60 chugging along just fine. Hardly ever come by here any more because it just works, take care all!!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
So, an update on my TS-MPPT 60
The battery charging part of this controller has worked flawlessly for as long as I've had it, no issues.
Where I have has issues is on the monitoring side of things. I have gone thru 3 of the remote displays. They work for some time, then one day, just a blank screen. Morningstar has provided replacements under warranty. I have given up on the remote displays.
As mentioned earlier in this thread I have struggled with the ethernet connection also, I have not been able to connect for a number of years, I have mostly written it off to my lack of computer skills.
Last week I decided again to try to connect via ethernet to no avail. I pulled the CC out and took it home to better "bench test", no joy. Contacted Morningstar to see if any helpful advice was available. Not really.
Even tried the serial port but got nothing, although that seems to be a known issue, as only 1 brand serial/usb cable is said to work well. I don't have it.
So being that all my issues are with communication ports, I see all these ports are on the same circuit board, I am wondering if my board is bad. Unit is out of warranty obviously. Was sort of suprised when Morningstar said they have no parts, and do no repairs. Just replace if problems arise. I guess that is more straight forward.
Anyway, unit still charging everyday, just no access to any info, good thing I have a tri-metric.
Perhaps if I was more tech savvy I might have recognized there was an issue earlier on and could have gotten it replaced under warranty.
Owell, it is a good solid CC, would buy it again as I think my issues are pretty isolated.
510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen. -
one thing with this unit installed around 2011 still working.BTW: this SCC is much faster than more mainstream at locking in the the MPPT, I was impressed.
TriStar-60 MPPT Controller v1.1.12 is to NEVER disconnect the battery power 1st. This will damage the board.Always disconnect the solar power input 1st then the battery power 2nd.I made this mistake many years ago, and first thought I bricked it, so ordered a new one.After calling Morning Star a very nice person walked me to find the unmarked modelof the Zener diode and capacitor.after a few minutes of fine soldering the unit started working again and the "replacement unit is still in its new box."I give them 5 starts just for that!Funny I did not have any problems the the liveview.html and use it daily in Firefox with Linux.the other program for the different settings I haven use for years.
- 230 Forum & Website
