Nothing like honesty, Flexmax MPPT charge controller
                    mcgivor
                    Solar Expert Posts: 3,854 ✭✭✭✭✭✭
                    Check out question #5......at least they're honest about their dishonesty
http://xihe-solar.en.made-in-china.com/product/mvhQSNCEZska/China-Fangpusun-Flexmax-MPPT-Solar-Panel-System-LCD-80A-Solar-Power-Charge-Controller-12V-24V-36V-48V-60V-Solar-Battery-Charge-Controller.html
            Amazing isn't it? They also "copy" Victron charge controllers and probably many other products. I'd be interested in seeing a head to head comparison of this FM 80 and the real thing, performance and quality.
             i have their 100/30 mppt controller and it is very nice unit for 58 bucks compared to the over 200$ victron one i have their 100/30 mppt controller and it is very nice unit for 58 bucks compared to the over 200$ victron one
 https://www.aliexpress.com/store/product/30A-12V-24V-MPPT-Solar-charge-controller-with-CE-ROHS-SGS-real-MPPT-function/535617_32563125020.html this the one i bought they also copy the xantrax pure sine wave inverters . now what is funny is when i use the ve direct cable the victron software says i have a victron blue controller and even has a serial number too
 600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
            Even the 2" lcd is visibly exactly like the real thing. I have the Victron version. You would think the OEM's would blow a gasket seeing their products copied like this.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
            Vinnie - is the plant running a 3rd shift this month ?
            I'll be buying the Fangpusun versions, I think Victron is a BIG waste of money. Bigly!!!
 I remain convinced the Fangpusun versions ARE OEM Victron, just re-badged. NOT copies - like that'd EVER happen.littleharbor2 said:Even the 2" lcd is visibly exactly like the real thing. I have the Victron version. You would think the OEM's would blow a gasket seeing their products copied like this.
 Well besides the Victron copies, Fangpusun also has exact copies of Outback products and Xantrex inverters. I doubt they are rebadged and ALL coming out of the OEM factory.OldMan said:
            At least they aren't trying to pass their products off as genuine. Providing they aren't infringing on patented or copywritten IP, good on em. Imitation being the sincerest form of flattery and all that.
 That said, my Chenglish isn't great, and IMHO the practicality of enforcing a warranty or product liability claim is dubious, so I'd personally take a pass.Off-grid.
 Ha! They have just deleted question 5.mcgivor said:Check out question #5......at least they're honest about their dishonesty
            Yeah I saw that. What did #5 Say?
 The question was do Fangpusun make controllers for OutbackMrM1 said:Yeah I saw that. What did #5 Say?
 Reply, No we just copy Outback, Steca and Victron.................................There was some other mumbo-jumbo about lower prices as well.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 232 Forum & Website
