Iron removal from water
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
I seasonally get iron in my water, and need to remove it before the main filtering. Research I've done shows that "greensand" style filters can trap the iron and then be backwashed with potassium permanganate and then returned to use. (much like a water softener and brine)
I have limited power and pressure (and water) for backwashing, and wondering if anyone has solved an issue like this ?
I'm hoping a mild pressure and let it soak overnight might work for the backwash/recharge ?
Use 2 tanks and swap them back and forth ?
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Some information that may be of interest https://www.best-osmosis-systems.com/water-filters-to-remove-iron/1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
You can oxidize (various chemicals or ozone or air) and then let it settle out in a holding tank. No backwashing needed.
As jonr said, oxidation is the usual method i.e. bubblier in a storage tank with a pressure tank beyond that...jonr said:You can oxidize (various chemicals or ozone or air) and then let it settle out in a holding tank.
"Main Filtering" what are you filtering out, whole house filters are normally not needed, they reduce the flow too much, and require maintenance.
This is a Solar site so I see no conflict in sending you to another site https://pumpsandtanks.com/index.php , good unbiased experts there unlike another well known plumbing site, Speedbump is our resident expert and I own the site and won't try to sell you anything, besides I have nothing to sell.
Rancher -
No problem posting relevant links that address questions and answers (even if they happen to sell something).
-Bill "moderator" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
We always rotate rain water to keep it fresh and chlorinated thru its storage cycle of 6 or 7 months.
So, yea swap it!
Or, harvest the rain, there are only a couple ways to goof up rain water and dozens for ground source water."we go where power lines don't" Sierra Nevada mountain area
cow_rancher said:sending you to another site https://pumpsandtanks.com/index.php , good unbiased experts there
RancherAfter 3 days, still no verification email. even used the cust service form to try to get a reply. I'll reg under a different addressEdit - never got anything at gmail but the reg via yahoo address went through fine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
So you are SolarMike, Welcome, l'll have to check on why gmail doesn't work.
Thanks, Rancher
