Iron removal from water
mike95490
I seasonally get iron in my water, and need to remove it before the main filtering.  Research I've done shows that "greensand" style filters can trap the iron and then be backwashed with potassium permanganate and then returned to use. (much like a water softener and brine)
I have limited power and pressure (and water) for backwashing, and wondering if anyone has solved an issue like this ?
  I'm hoping a mild pressure and let it soak overnight might work for the backwash/recharge ?
Use 2 tanks and swap them back and forth ?
  • mcgivor
    Some information that may be of interest https://www.best-osmosis-systems.com/water-filters-to-remove-iron/
  • jonr
    You can oxidize (various chemicals  or ozone or air) and then let it settle out in a holding tank.  No backwashing needed.
  • cow_rancher
    cow_rancher Solar Expert Posts: 117 ✭✭✭✭
    As jonr said, oxidation is the usual method i.e. bubblier in a storage tank with a pressure tank beyond that...
    "Main Filtering" what are you filtering out, whole house filters are normally not needed, they reduce the flow too much, and require maintenance.
    This is a Solar site so I see no conflict in sending you to another site https://pumpsandtanks.com/index.php , good unbiased experts there unlike another well known plumbing site, Speedbump is our resident expert and I own the site and won't try to sell you anything, besides I have nothing to sell.
    Rancher
    BB. Super Moderators, Administrators Posts: 33,743 admin
    No problem posting relevant links that address questions and answers (even if they happen to sell something).
    -Bill "moderator" B.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,119 ✭✭✭✭✭✭
    We always rotate rain water to keep it fresh and chlorinated thru its storage cycle of 6 or 7 months.
    So, yea swap it!
    Or,  harvest the rain, there are only a couple ways to goof up rain water and dozens for ground source water.
    E-mail offgridsolar@sti.net
    edited November 2018 #7
    Rancher
    After 3 days, still no verification email.  even used the cust service form to try to get a reply.  I'll reg under a different address
    Edit - never got anything at gmail but the reg via yahoo address went through fine.
  • cow_rancher
    So you are SolarMike, Welcome, l'll have to check on why gmail doesn't work.
    Thanks, Rancher
