Lightning strikes again? Morningstar TS 60
Struck by lightning twice in a year? Ugh! Would a lightning rod help?Off-grid.
Where is the one you have positioned in the wiring ? Do you have more than 1 SPD?
Estragon said:Struck by lightning twice in a year? Ugh! Would a lightning rod help?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
That's a lot of smoke for a diode. Or it was a very large diode. I'd consider it all toast. Expect other electronics to be weakened and about to fail.
Just as a matter of interest, are the big zig-zaggy things how the CC transfers heat to the external heat sink fins?
If so, maybe a lower resistance path to ground? Having gone miles, I'm sure lightning does what it wants, but maybe that's a tasty target. It would also avoid a SPD on the DC wiring that way?Off-grid.
SPD wise, DC, one at incoming solar disconnect, downstream side, AC, main live bus.
Lighting rod? Do have a mast with an air terminal, was hit 4 days after installing, took out the inverter no SPD at that time.
The zigzag thing is an aluminum bar with a stainless steel spring, under which is a plastic piece with fingers that pass through the PCB appling pressure to the mosfets against the heat sink , the 3 screws thread into the heat sink.
Bad luck perhaps, the mast is intended to offer a path to ground other than a structure, dose it contribute to the damage caused, who knows, my understanding is that if lightning is going to strike in the area the point of contact is generally concluded at the last micro second so the mast offers a path of least resistance.
Bad luck perhaps ...
Since you and your family are still here to tell the tale, I guess it depends how you define bad luck
Sometimes bad stuff happens to good people. It just is.Off-grid.
Reasoning with lightning can be as reasoning with hurricanes (cyclones)"we go where power lines don't" Sierra Nevada mountain area
Out of curiosity I made contact with tech support including images, asking what they thought the cause of failure might be, without furnishing any details, emphasis on no warranty claim despite being within warranty. The response was. The damage to D3 is consistent with a high voltage transient, was lightning present in the area? Naturally I answered honestly that it was likely and that I was just interested in their opinion.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Looks like it to me.... Only crazy people would give warranty for that!
I once visited a boat that was hit and in the day all the lighting was incandescent.
Every light bulb exploded and there was glass everywhere. You can imagine what the inside of electronics looked like.
They lost 3 garmin gps units. they were over 1,500 us dollars then."we go where power lines don't" Sierra Nevada mountain area
Since you are running low volts maybe you could try installing an electric fence lightning arrestor on your + and - solar panel wires going to ground?
oil pan 4 said:Since you are running low volts maybe you could try installing an electric fence lightning arrestor on your + and - solar panel wires going to ground?
DoD= depth of discharge= amount removed from that battery SoC= state of charge= amount remaining in that batterySo, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoCA/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use) -
I saw that and it doesn't appeared to have helped much.
The electric fence lightning protectors are just a good old fashioned spark gap and they only cost a few dollars.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
By the time a " good old fashioned spark gap " triggers, the electronics are way past dead. The midnight SPD's come in several voltage protection ranges, so you can maintain as small as possible "unprotected" voltage range.
Is one of those fancy protection methods a spark gap?
If not then wouldn't we be trying the same thing and expecting a different result?
I believe that is the definition of insanity.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
SPD's do not use a spark gap, there are various types which employ different semiconductors varistors, thyristors, diodes etcetera to divert unwanted harmful transients to ground.
https://www.nemasurge.org/how-spd-s-work/?
I'm well aware of varistors, I put them on all my welders and air compressors.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
