charging battery bank with an alternator
cockneybob2
Registered Users Posts: 18 ✭✭
hi , I have a used small 4 hp diesel engine and a used 12 volt 60 amp car alternator both work fine , instead of connecting alternator cables straight to the battery bank to charge , is there any reason I can not connect the alternator cables into a totally separate stand alone mppt or pwm charge controller , would this work like a wind turbine and charge the battery bank .
thanks
I suspect the output voltage would be too low for an mppt controller.Off-grid.
ok , what if I purchased say a 24 volt alternator , would that work in principle
Without a voltage regulator, the alternator would probably produce enough voltage to work with MPPT, with a regulator it would have too low a voltage and even with a 24V regulated alternator, it would more than likely confuse the tracking of the MPPT, with each trying to take control. You could of course use the regulated 12V alternator without a controller to add current, but it's not the most efficient use of fuel, this includes the theroy with a charge controller, as the battery becomes close to fully charged the more fuel is wasted and this is the reason generators are used as backup, rather than prime charging sources.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
thanks mcgivor , this charging procedure is only for an emergency , in case all else fails , have seen an economically priced solar and wind turbine charge controller , so guess that's the way to go , not bothered about the efficiency or economics of charging the battery bank as will only use is system once in a blue noon if at all , as I have most of the gear , I just wondered if it would work , thanks
Not all MPPT controllers are rated to work with a non-solar power source. They depend on the "source" following solar PV rules, generators & chargers have vastly different impedance response
If the MPPT controller has a higher amp rating than the alternator, it will draw too much (unless the alternator has current limiting or a fuse). Plus alternators require voltage to start producing power. I agree - connect the regulated alternator directly to the batteries.
