Is c10 battery in anyway performs better in offgrid setup
solarking
Registered Users Posts: 67 ✭✭
Is it a myth c10 battery performs better than c20 battery in solar offgrid setup or it is just a marketing gimmick?
Every lead-acid battery has a rated storage capacity depending upon how quickly you drain power from it.
Some manufacturers publish their battery capacity ratings for numbers between 1 hour and 120 hours. This allows you see what your storage capacity will be for a specific application.
I have never heard anyone make that claim that you mention above. Where did that come from?
Marc
By "c10", are you referring to the capacity rating (i.e. X amp hour at a 10 hour rate of discharge)? If so, the 10hr rate capacity battery would have a higher capacity at a 20hr rate than an equally rated 20hr rated battery. For example, two batteries both rated at 100ah, one at c10 and one at c20. The c10 one might be 120ah when discharged at a 20hr rate vs 100ah for the c20 one.
A caveat to this is the batteries may be rated at different discharge rates because they may be designed for different applications. A c10 battery may be designed to deliver higher current for a short time, in a UPS for example. Off-grid, we want batteries designed for slower, deeper discharge (thicker plates, etc). Non deep cycle batteries won't last long in a deep cycle application.Off-grid.
Please note that some manufacturers have used C20 or c10 to describe charging rates as well. I believe some Gel batteries can only handle a 1/20th charge rate. This would be too slow for most solar applications.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Good call - I tend forget about that.Photowhit said:Please note that some manufacturers have used C20 or c10 to describe charging rates as well. I believe some Gel batteries can only handle a 1/20th charge rate. This would be too slow for most solar applications.
It would help to post links to examples of the two batteries being considered.
Hi Jonr,jonr said:It would help to post links to examples of the two batteries being considered.
6LMS150L(c10) vs IT500(c20)
not to be confused with US Exide these are different
Comparing the specs I think c20 200AH battery is same as c10 150AH. Correct me if I am wrong
I'd say that a C10 rating is worth an extra 10-20% over C20 - ie, C10@150AH might rate C20@172AH. For solar use, get the first one - it has more lead in it (it's heavier) and will survive more cycles (based on the specs).
Exide 6LMS150
C10 Rating = 150AH down to 10.8 Volts
80% DOD = 1,500 cycles = 4.1 years
50% DOD = 3,000 cycles = 8.2 years
20% DOD = 5,000 cycles = 13.6 years
Even for "Lab Cycles" that is very impressive.
So, how will age / time affect those Lab Cycles, over a 5 year period?
In the real world, can we expect 50% DOD or 75AH every day for 5 years?
Add temperature to that list, 10°C over 25 would significantly reduce the life expectancy, as much as 50% or more.
mvas said:Exide 6LMS150
In the real world, can we expect 50% DOD or 75AH every day for 5 years?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Temp would almost certainly affect lifespan. Would it affect both equally?Off-grid.
, I am actually buying this exact model battery but i am pretty sure the average temperatures in the day here are 30c year around, close to 40 in summer and around 25 in winters but even 5 years @ 50% DOD for the price we pay is not bad at all
