Which controller for this app
lipets
Solar Expert Posts: 61 ✭✭
I have 4 265 watt panels that I want to use to charge 8 T-105's
I was thinking two Kid units, but wanted to get your opinions
where are you going to travel to? season? battery voltage when assembled? Specs/brand for those panels? Will you expand to more panels> etc etc
Is this for a 48V battery system ?
Hi, this is a 12 V batt bank, I'll travel mostly based in central FL then hard to say for a total of 3-4 months for weeks at a time May-Oct.
the panels are Hyundai, voc, 37, isc,8.6, vmp 31.
I planed on wiring them in parallel due to possible shading issues when parked.
4 panels are max no expanion planned, my last setup was with 600 watts and it was almost enough
You are going to need a MPPT CC with those panels, 4×265W too high for 2 MS Kid CC at 12V, to the best of my knowledge. Cant go 24V? Would make things somewhat easier.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
the Kids can handle them, talk to support, can't do 24v
looking for alternative to two kids at about $600
looking at OUTBACK, FM80-150VDC, MPPT CONTROL, FLEXMAX 80 CHARGE CONTROL 80A 12-24-48V
thanks
Midnite Solar Classic 150 SL, solar only. Street price in the $500.00 range. I see one for $491.00 W/free shipping.
lipets said:the Kids can handle them, talk to support, can't do 24v
thanks1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
For a camper, I might suggest a fanless design, such as the Morningstar TriStar MPPT 60. While it says It handles up to an input of 800 watts for 12 volt conversion, Normally that is all you will have with 4 - 265 watt panels, more won't hurt the charge controller. This si the same reasoning that allows the kid to handle more.
https://www.solar-electric.com/motr60ampmps.htmlHome system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 228 Forum & Website
- 653 Solar Water Pumping
- 619 Discussion Forums/Café
