Which controller for this app
I have 4 265 watt panels that I want to use to charge 8 T-105's
I was thinking two Kid units, but wanted to get your opinions
  • westbranch
    where are you going to travel to?  season? battery voltage when assembled? Specs/brand for those panels? Will you expand to more panels>  etc etc
    West Chilcotin, BC, Canada
    Is this for a 48V battery system ?
  • lipets
    lipets Solar Expert Posts: 61 ✭✭
    Hi, this is a 12 V batt bank, I'll travel mostly based in central FL then hard to say for a total of 3-4 months for weeks at a time May-Oct.
    the panels are Hyundai, voc, 37, isc,8.6, vmp 31.
    I planed on wiring them in parallel due to possible shading issues when parked.
    4 panels are max no expanion planned, my last setup was with 600 watts and it was almost enough
  • mcgivor
    You are going to need a MPPT  CC with those panels, 4×265W too high for 2 MS Kid CC at 12V, to the best of my knowledge. Cant go 24V? Would make things somewhat easier.
  • lipets
    edited March 2017 #6
    the Kids can handle them, talk to support, can't do 24v
    looking for alternative to two kids at about $600
    looking at OUTBACK, FM80-150VDC, MPPT CONTROL, FLEXMAX 80 CHARGE CONTROL 80A 12-24-48V
    thanks
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
    Midnite Solar Classic 150 SL, solar only. Street price in the $500.00 range. I see one for $491.00 W/free shipping.
  • mcgivor
    thanks
    My error, good to see you have researched your opinions, was thinking along the lines that the Kid was 30A maximum, alway easier with one controller and often cheaper.
  • Photowhit
    For a camper, I might suggest a fanless design, such as the Morningstar TriStar MPPT 60. While it says It handles up to an input of 800 watts for 12 volt conversion, Normally that is all you will have with 4 - 265 watt panels, more won't hurt the charge controller. This si the same reasoning that allows the kid to handle more.
    https://www.solar-electric.com/motr60ampmps.html
