Need Help
ibdumb
ibdumb Registered Users Posts: 3
Have 2 panels on pole mount. What size wire do I use to run from panels to input breaker and then to charge controller? and from battery to charge controller?
Also from battery to inverter. I assume they will all be the same size??? The distance is about 20 feet or less.
THANKS in advance
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    edited January 2017 #2
    We'll need to know the size of the panels, volts and amps, and how they are configured, in series or parallel, if in parallel will they be combined at the panels or at the charge controller.
    The inverter to battery will depend on the size of the inverter and distance to the battery bank. Also the voltage the inverter will run at...
  • ibdumb
    2 Solar World 285 watt panels in series with H4 connector cables.
    Tri Star MPPT charge controller 45 amp up to 150 VOC input, 12 - 48 volts, 12v-600 watts 24v-1200 watts 11.4' x 5.1 x 5.6'.
    The inverter is a 2800 watt, 12 volt/125 amp pfc charger ETL/UL 1741 listed. Less than 12 feet to batter bank.
    I'm trying to run a 230 volt water pump.
    Hope this is enough info to help with an answer. Getting complicated eh???
    panel specs?
    Assuming they are these panels;
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjntKiO-MTRAhUM42MKHU1EBGsQFghCMAA&url=https://www.solarworld-usa.com/~/media/www/files/datasheets/sunmodule-plus/sunmodule-solar-panel-285-mono-ds.pdf&usg=AFQjCNEaygXj9Gdsmq_fCTtdfXH9kQ_ZvA&sig2=Us7IzGp8bfPqEA-21U-GzA
    They are 31.3volts vmp and 9.2 amps IMP, in series they would max around 18.4 amps (at 31.3 volts). for the 20 foot trip to the charge controller, You will lose about 2.25 percent of voltage with 10 gauge wire, usually less than 2 percent as panels actually produce about 75% of their panel rating. That is with in the 2-3% we like to see, Your charge controller I would assume is very near your batteries?
    The distance from your battery bank to inverter is very large at 12 feet, do to the low voltage. I don't know what your pump requires, watt wise, but to deliver full wattage with a 2-3% drop in voltage, 2800watts / 12= 233 amps!
    This would give you 2.25% loss in voltage with 4/0 cable, even this may create problems with voltage sag, depending on the size of your battery bank and Low voltage warning/shut off.
    Others will be along to check my figures, I'm not sure where the power factor correcting charger comes into play.
  • mcgivor
    Think parallel was meant as series would double the voltage.
    edited January 2017 #7
    'My bad' He does say in series, So It should be 9.2 amps at 62.6 volts, so I think he can get away with 12 gauge with less than 2% loss. Good catch Mcgivor!
  • mcgivor
    edited January 2017 #8
    Series may be too high as it appears a 12V battery is being used, if that is the case, parallel would be a better option, would it not?
    mcgivor said:
    Series may be too high as it appears a 12V battery is bei used, if that is the case, parallel would be a better option, would it not?
    Yes, I agree, and it's close enough to have minimal losses with reasonable wire size.
    So 'IB', Charge controllers tend to have the best efficiency at about 2x the system voltage, so charging a 12 volt battery would be around 14 volts... if you run higher voltage they will handle it up to their capacity, but generate more loss in the form of heat. Heat also tends to shorten the life of electronics.
    Tell me more about the pump.  1/3hp ?  deep well?  pressure booster ?
    That voltage drop from battery,12 feet to inverter is going to be tough,  Anyway to move the inverter closer and run the 230V wire ?
    If I was to do this over, I'd base it on a 24 or even 48V system to be able to handle that pump.  Most pumps have a pretty awful starting surge:
  • ibdumb
    Photowhit said:
    Sorry guys, I do have 4 batteries CB6-250AH. 2 will be in parallel and 2 in series. So from above comments looks like10 ga will work...Thanks for all the comments...Will try to get all the info in the next time.
