Battery replacement query
mcgivor
Solar Expert Posts: 3,854 ✭✭✭✭✭✭
Planning for an expansion, a new and larger battery will be needed, so the search for 2 volt cells has led me to 2 sippliers, one carries Trojan and the other Hoppecke. Has anyone had any experience with the Hoppecke? Trojan seems to be quite well documented, sadly other well documented brands eg. Surrette and Concord are not available locally.
Most other suppliers carry monoblock 12V, up to 250Ah, there is of course golf cart batteries but my objective is to get away from the monoblocks. Attached is a pdf of the cells of interest, would appreciate any feedback, thanks.
since your going the 2 volt cell way i would consider buying a forklift battery as they are 2 volt cells600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
I have no experience with that battery, but their DOD/Cycle curves look good. 8,000 to 6,500 cycles at typical off grid DOD of 20% to 30%. Heck, even at 50%, they are pushing up toward 3,000.mcgivor said:Planning for an expansion, a new and larger battery will be needed, so the search for 2 volt cells has led me to 2 sippliers, one carries Trojan and the other Hoppecke. Has anyone had any experience with the Hoppecke? Trojan seems to be quite well documented, sadly other well documented brands eg. Surrette and Concord are not available locally.
I am not familiar with the DIN test standards, only the BCI test methods. It is possible that a difference in method can skew the numbers from a direct comparison, but their numbers are so large that I don't think it matters.
Yes the specs are pretty impressive but they do come at a cost, got a quote of just under $2000 for a 24V 420Ah set. As far as the DIN testing I'm sure it is at par with BCI, being Germans and all, still waiting on a Trojan quote.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I didn't mean that DIN might not be up to snuff. I just meant that different test methods can give different results.
The BCI cycle testing for instance, is based on a very heavy load for a shorter duration - not the kind of discharge profile seen in a typical off grid system. If the DIN standards use a low discharge rate, the numbers would be different. I have noted lately that some people are posting cycle estimates based on a "modified BCI test" approach.
The price of $2000 doesn't seem high to me for twelve (12) 420 ah, 2v batteries. Concorde and Fullriver do not offer 2v batteries that small.
Did a search on DIN testing came up with some results but you have to buy the information.The quote included other sizes up to 2000Ah at $9000 for 12×2v but I'm no where that capacity requirement....yet..lol1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:Yes the specs are pretty impressive but they do come at a cost, got a quote of just under $2000 for a 24V 420Ah set. As far as the DIN testing I'm sure it is at par with BCI, being Germans and all, still waiting on a Trojan quote.
Was that a 6 hour or a 20 hour rate?
I finally opened your link, looks like that's a 100 hour rate. To compare with other options, most use a 20 hour rate. might call them 360 ah batteries.
Attached on the OP is the PDF, no 20 hour but 24 hour is the closest.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Nice that they're available in such a wide variety of sizes. Where do they ship from?
I know the 20hr rate is sort of standard, but the way most of us use them the 100hr rate is probably realistic.Off-grid.
Estragon said:Nice that they're available in such a wide variety of sizes. Where do they ship from?
Likely, but he's shopping for batteries, it would be good to compare apples to apples.
The batteries are shipped from Bangkok Thailand, and includes a technician for set up and commission. All the batteries available, here be it, Hoppecke, Fiamm, Fronius,Weida or Axitec all use the European Din testing method, only Trojan uses the BCI test, so it is a little hard to compare apples to apples. Surrette and Concord are options but they ship from Singapore and would rather not deal with importation issues. The Trojan supplier has not responded yet, over a week, all I need is a price from them.
Photowhit said:Estragon said:Nice that they're available in such a wide variety of sizes. Where do they ship from?
American companies lean on BCI simply because it is standard here. I wouldn't let any differences get in the way of choosing a battery that you like. If it takes more than a week to just get a response to a request for quotation - how long do you suppose that it will take to get customer support help if there is a problem?
For what it's worth: Concorde Sun Xtender publishes their primary data based on the 24 hr rate along with 8,48, 72, 120 etc. I suspect that their choice has to do with off grid folks who tend to think in terms if those time blocks instead of "1 day minus 4 hours" for the BCI standard rate of 20 hours.
Note that some manufacturers like East Penn Deka and MK brands publish the 100 hour rate as the battery capacity. You have go looking for the 20 hr rating.
