Battery caps
JESSICA
JESSICA Solar Expert Posts: 289 ✭✭
When I bought my new batts one or two months ago, one of you (I think it was a moderator) recommended I should buy these Water Battery Caps: http://www.solar-electric.com/batwatmiscap.html
My question: Will they fit my Trace batteries? They don't have "caps", but something like a plastic bar with 3 plugs in it.
A pic. is worth a 1,000 words:
    Re: Battery caps
    The "single" caps have a push and twist bayonet lug in them. These look very different. Maybe you are stuck, or trace has "their own" watering system they are looking to sell.
  • dagr51
    dagr51 Solar Expert Posts: 72 ✭✭✭✭
    Re: Battery caps
    I have similar 3-way caps on my GC batteries. Can't you just discard the 3-way and replace with water miser caps?
  • JESSICA
    Re: Battery caps
    dagr51 wrote: »
    That is, precisely, my question!!!!
    Yes, I can discard the 3-way bar; but: will those miser caps fit the holes?
    I don't want to buy them and then find out they don't fit.
    By the way: The 3-plugs bar is of the "twist" kind. I place it on the batteries and then twist it about half an inch until it "locks". Sorry, this is as far as my english goes.
    Photowhit Solar Expert Posts: 6,006 ✭✭✭✭✭
    Re: Battery caps
    dagr51 wrote: »
    Similar to what the poster is showing?
    I've seen Golf cart batteries coming with what use to be called speed caps, were one action twists all 3 caps, and then you lift all three together as a unit. I think my Sams Club batteries came with them.
    I'm relativly sure the miser caps would work on these.
    Re: Battery caps
    If you have a car, truck or tractor battery with individual twist-lock caps, try one on the battery - see if it will twist and lock in. The water saver caps (non catalyst) are a little taller than the plain caps, and they also need space to flip up for watering.
  • icarus
    Re: Battery caps
    Call th vendor and ask. Find a vender who sells both water miser caps and. Ybqtteriew,, ie NAWS.
  • JESSICA
    Re: Battery caps
    Photowhit wrote: »
    Photowhit:
    Yes, exactly those. In fact, my new batteries use the same "speed bar" as those sold by Sams.
    Tony:
    Are you serious? That is a question one should NEVER ask a vendor!
    No matter what the right answer is, every time you ask a vendor if the item they sell would fit, their answer will always be "Of course it will fit". So, why bother?
  • PhilS
    PhilS Solar Expert Posts: 370 ✭✭✭
    Re: Battery caps
    Those same combo-twist-bar-things came on my last set of batteries and my Water Miser caps fit just fine.
    Phil
  • icarus
    Re: Battery caps
    JESSICA wrote: »
    Photowhit:
    Tony:
    Then choose another vendor! I suggest that a good, honest, ethical vendor would give you the straight answer,, since the last thing they want is a unhappy customer.
    I include our site sponsor, as an example of a good vendor.
    T
  • waynefromnscanada
    Re: Battery caps
    icarus wrote: »
    T
    Agree totally. Yes, there are unethical vendors out there, but they usually don't stay in business for very long. In the meantime, there are many good, reliable vendors who yes, need to make a profit to stay in business, but also strive to please their customers. NAWS is definitely among the best. Not all business owners are psychopaths.
